You can connect to your Nativo data from Power BI via the high-performance Nativo ODBC Driver. We'll walk you through the entire setup.
  • Configuring a secure connection to Nativo
  • Working with Nativo data directly inside Power BI
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Nativo Connector.
Create data source using Nativo ODBC Driver
To get data from Nativo using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Nativo" from the list of Popular Connectors. If "Nativo" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    NativoDSN
    Nativo
    • Configure the authentication in Nativo.
    Http
    Nativo authentication
    Please refer to external API reference
    1. Set Authentication Type to Http [Http]
    NativoDSN
    Nativo
    Http [Http]
    https://api.nativo.com/v2
    Api Key
    Api Secret
    Find full details in the Nativo Connector authentication reference.
    ZappySys API Driver - Nativo
    Read and write Nativo advertising data effortlessly. Integrate, manage, and automate campaigns and performance — almost no coding required.
    NativoDSN
  7. Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from Nativo. Hit OK button to use this query in the next step.
    SELECT * FROM Orders
    Some parameters configured in this window will be passed to the Nativo API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful data much faster.
    NativoDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Nativo API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Nativo servers).
Connect to Nativo data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose NativoDSN and continue:
    NativoDSN
    NativoDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from Nativo in a Power BI report:
If you wish to import Nativo data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
NativoDSN
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Nativo ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=NativoDSN"}
    dsn=NativoDSN
    dsn=NativoDSN
    = Odbc.Query("dsn=NativoDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports Nativo data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from Nativo Service
    SELECT * FROM OPENQUERY([LS_TO_NATIVO_IN_GATEWAY], 'SELECT * FROM Orders')
    DirectQuery option for Power BI (read Nativo data example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and load the data. Your Nativo data is now linked live rather than imported.
    NativoDSN
    NativoDSN
    DRIVER={ZappySys API Driver};ServiceUrl=https://api.nativo.com/v2;CredentialType=HashSignature;Timeout=100000;SoapWssPasswordType=Notset;JwtCustomClaims=;RetainCookies=False;UseProxy=False;ProxyUrl=;UseProxyCreds=False;ProxyUserName=;DoNotUseDefaultProxy=False;UseClientCertificate=False;CertificatePath=;CertificateStorageType=CurrentUser;CertificateStoreName=My;CertificateThumbprint=;RetryMode=None;RetryCountMax=3;RetryWaitTimeMs=2000;RetryMultiplyWaitTime=False;RetryMessageList=;RetryStatusCodeList=;AuthScheme=Bearer;TokenAuthHeader=;TokenUrl=;TokenRequestData=;TokenRequestHeaders=Accept:*/*||Cache-Control:no-cache;TokenRequestMethod=;TokenRequestContentType=Default;TokenResponseContentFilter=;TokenResponseValueExtractMode=Body;TokenResponseCookie=;TokenResponseHeader=;TokenResponseContentType=None;TokenExpirationTimeInSeconds=3600;EnableRequestHashing=False;HashAlgorithm=sha256;HashSignatureFormat=[$password$][$timestamp$];HashSignatureFormatForLogin=;ExtraHeaders=nativo-hash:[$signature-hex$]||nativo-timestamp:[$timestamp$]||nativo-token:[$userid$];ExtraHeadersForLogin=;HashTimestampFormat=unix-epoch;HashTreatSecretAsNonBase64=True;HashSignWithApiKey=True;RetainSameConnection=False
Nativo Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Nativo operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
In some situations, you may need to provide Nativo data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Nativo data source in the gateway
In this section we will create a data source for Nativo in the Data Gateway. Let's follow these steps to accomplish that:
    NativoDSN
  4. When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Nativo ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      NativoDSN
      NativoDSN
      NativoDSN
  5. Then set the default database property to NativoDSN (the one we used in the Data Gateway):
    NativoDSN
    NativoDSN
Finally, we are ready to read data from Nativo in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to Nativo data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Nativo in Power BI and integrate your data — all without writing complex code.
