SSIS Web API Destination can be used to POST multiple requests to any Web API Endpoint (POST data to URL). It support advanced Authentication mechanism such as OAuth, Basic Auth. Data can be in any format such as CSV, JSON, XML for other. It also supports Batch operation so you can group multiple request in one batch.
In this tutorial we will learn how to POST multiple requests to any Web API Endpoint (POST data to URL). In this case its from CSV Source and Generate JSON data and POST Data through Web API Destination.
  5. Here, In Visual Studio, drag and drop the ZS CSV Source (Web API or File), JSON Generator Transform and Web API Destination in the design surface and join the components with the blue arrow.
    SSIS Web API Destination - Drag and Drop Components
  6. Here, you can use any suitable our ZS Source Adapters too. But, we are going through CSV Source (REST API or File) and we need HTTP Connection for Web API Destination. To create HTTP Connection click here. If you don't have any credentials do not worry about it, you can use http://httpbin.org/ for practice it.
  7. Double click on ZS CSV Source (Web API or File) Configure it. For more information about CSV Source click here.
  8. Set AccessMode to File path or web URL. Enter following URl.
    https://zappysys.com/downloads/files/test/invoices.csv
    In the settings tab set HTTP Request Method to GET. Check on First row has column name.
    SSIS CSV Source (Web API or File) - Configure
  9. Click on preview button to see our configuration are OK.
  10. Click on OK to save CSV Source setting UI.
  11. Now, double click on ZS JSON Generator Transform to configure it.
  12. Here, Right Click on DataSet from left panel of JSON Generator Transform, select Edit. And than, In Add / Edit Dataset dialogbox rename it.
    SSIS JSON Generator Transform - Configure Edit DataSet
  13. Now, Right Click on Mappings from left panel of JSON Generator Transform, select Add Element(s)(Below this node). And than, In Add/Edit Attribute dialogbox, select Add Multiple (Bound) and select column.
    SSIS JSON Generator Transform - Configure Add Element(s)
  14. Again, Right Click on Mappings from left panel of JSON Generator Transform, select Add Unbound Nested Element(Below this node). And than, In Add/Edit Attribute dialogbox, Enter Output Alias name and click on OK.
    SSIS JSON Generator Transform - Configure Add Unbound Element
  15. Then, Right Click on Unbound Nested Element we have created in previous step from left panel of JSON Generator Transform, select Add Element(s)(Below this node). And than, In Add/Edit Attribute dialogbox, select Add Multiple (Bound) and select column.
  16. Click on OK to save JSON Generator Transform setting UI.
  17. Now, double click on ZS Web API Destination to configure it.
  18. Select HTTP Connection we have created before. Here you can use Direct URL instead of any Connection (HTTP, OAuth and SalesForce) in case of, if you do not required to pass credentials. Set POST to HTTP Request Method, In the Body (Request Data) click on Pencil Button and Select Insert Variable then columns and Select <%ZS_JSON_OUT%>. Body Content Type should be suitable.
    SSIS Web API Destination - Configure
  19. In the Batch Settings (For Body), Enable submitting multiple records in a single Web Request (Bulk operation). Set Body Header, Footer, Body Row Separator and Batch Size.
    SSIS Web API Destination - Configure Batch Size
  20. Click on OK button to save Web API Destination setting UI.
  21. From the SSIS toolbox drag and drop Trash Destination on the data flow designer surface.
  22. Now single click on the Web API Destination, once you see red arrow from destination ... connect it to Trash Destination.
  23. Double click on ZS Trash Destination to Configure it.
  24. Click on OK button to save Trash Destination configure setting UI.
  25. Thats all, Just Save and Run or Execute the package. click here to see how to use Fiddler.
    SSIS Execute the Package
HttpRequestUrl API URL you like to call
HttpRequestMethod Http Web Request Method (e.g. POST, GET, PUT, LIST, DELETE...). Refer your API documentation if you are not sure which method you have to use.
HttpHeaders Set this if you want to set custom Http headers. You may use variable anywhere in the header value using syntax {{User::YourVarName}}. Syntax of Header key value pair is : <request><header><name>x-myheader-1</name><value>AAA</value></header> <header><name>x-myheader-2</name><value>BBB</value></header></request>
HttpRequestData User defined data you wish to send along with your HTTP Request (e.g. Upload file data, Form POST data). Usually you have to set content-type of your data but if you select RequestMethod=POST then system will automatically set content-type=application/x-www-form-urlencoded.
HttpRequestContentType Specifies content type for data you wish to POST. If you select Default option then system default content type will be used (i.e. application/x-www-form-urlencoded). If you specify Content-Type header along with this option then header value takes precedence.
TextPlain [1] Text (text/plain)
ApplicationJson [2] JSON (application/json)
ApplicationXml [3] XML (application/xml)
TextXml [4] XML (text/xml)
TextXmlUtf8 [5] XML (text/xml;charset=UTF-8)
TextHtml [6] HTML (text/html)
ApplicationFormUrlencoded [7] Form (application/x-www-form-urlencoded)
ApplicationOctetStream [8] Binary (application/octet-stream)
Raw [9] Raw (No content-type)
MultiPartMixed [10] Multipart Mixed (multipart/mixed)
ApplicationGraphql [11] GraphQL (application/graphql)
ContinueOnUrlNotFoundError If this option is true then component will continue without exception on 404 error (Url not found). This allows you to consume data gracefully.
DisableExpect100Continue Set this option to true to disable Expect 100-continue negotiation for POST requests (or any requests with BODY). By default client waits for server response for POST request (this is done via Expect: 100-continue header in POST request). Disable this option to improve response time significantly in some cases (Disabling this option is not recommended for larger POST requests- i.e. File Upload)
IgnoreCertificateErrors Ignore SSL certificate related errors. Example: if you getting SSL/TLS errors because of certificate expired or certificate is not from trusted authority or certificate is self-signed. By checking this option you will not get SSL/TLS error.
AllowUnsecureSuite Allow unsecure ciphers/suites and curves for SSLS/TLS communication. Use this option to communicate with web servers which needs legacy / unsecured ciphers support. This option is only trigged when you change default SSL/TLS Version on advanced settings tab.
EnableCompressionSupport Enable support for gzip or deflate compression (for deflate you must turn on [Tls 1.0 Or Higher] Option on Advanced Settings - Security Protocol for HTTPS). When you check this option compressed response automatically de-compressed saving bandwidth. This option is only valid if web server supports compressed response stream. Check your API documentation for more information.
SecurityProtocol Specifies which security protocol is supported for HTTPS communication. Using this option you can enable legacy protocol or enforce to use latest version of security protocol (Note: TLS 1.2 is only supported in SSIS 2014 or Higher).
Default [0] System Default
Ssl3 [1] SSL v3.0
Tls [3] TLS v1.0
Tls11 [5] TLS v1.1
Tls12 [7] TLS v1.2
Tls13 [9] TLS v1.3
WaitTime Wait time in milliseconds (Pause after each request). 0=No wait. Use this delay time if your API has limit on how many requests you can make in certain time frame.
EnableParallelRequests Enable multiple requests using parallel threads.
MaxParallelThreads Maximum parallel threads to use for processing multiple web requests.
EnableBodyBatch By default one request is sent for each input row. If your API supports multiple records in a single call via HTTP Body then enable this setting. See also BodyBatchSize, BodyHeader, BodyFooter and BodyRowSeparator property.
BodyHeader When you have to wrap input content between opening and closing tags for each call then set this property to specify opening for body content. For Example if you want to build Body like this (send max 100 rows per call) ==> { records : [ {...}, {...}, {...} ] } then you can set BatchSize=100, BodyHeader as "{ records: [" , BodyFooter as "] }" and BodyRowSeperator as comma {,}. This property is ignored if EnableBodyBatch=false.
BodyFooter When you have to wrap input content between opening and closing tags for each call then set this property to specify closing for body content. For Example if you want to build Body like this (send max 100 rows per call) ==> { records : [ {...}, {...}, {...} ] } then you can set BatchSize=100, BodyHeader as "{ records: [" , BodyFooter as "] }" and BodyRowSeperator as comma {,}. This property is ignored if EnableBodyBatch=false.
BodyBatchSize If your API supports multiple records via HTTP Body then change this setting > 1 to include multiple upstream records into single call. See also BodyHeader, BodyFooter and BodyRowSeparator property. This property is ignored if EnableBodyBatch=false.
BodyRowSeparator When you submit multiple rows in a batch you can separate multiple documents / records using custom separator (e.g. in JSON Array you can use comma {,} as record separator if POST document is in array format [ {...}, {...}, {...} ] ). For last row of batch blank separator is used.
TreatResponseAsBinary Returns response data as binary data (e.g. Byte Array). Check this option is response is Zip file, Image file or any non text data which needs to be exported as raw data without any encoding.
IsMultiPartUpload Set this option if you want to upload file(s) using either raw file data (i.e., POST raw file data) or send data using the multi-part encoding method (i.e. Content-Type: multipart/form-data). A multi-part request allows you to mix key/value pairs and upload files in the same request. On the other hand, raw upload allows only a single file to be uploaded (without any key/value data). ==== Raw Upload (Content-Type: application/octet-stream) ===== To upload a single file in raw mode, check this option and specify the full file path starting with the @ sign in the Body (e.g. @c:\data\myfile.zip) ==== Form-Data / Multipart Upload (Content-Type: multipart/form-data) ===== To treat your request data as multi-part fields, you must specify key/value pairs separated by new lines in the RequestData field (i.e., Body). Each key/value pair should be entered on a new line, and key/value are separated using an equal sign (=). Leading and trailing spaces are ignored, and blank lines are also ignored. If a field value contains any special character(s), use escape sequences (e.g., for NewLine: \r\n, for Tab: \t, for at (@): @). When the value of any field starts with the at sign (@), it is automatically treated as a file you want to upload. By default, the file content type is determined based on the file extension; however, you can supply a content type manually for any field using this format: [YourFileFieldName.Content-Type=some-content-type]. By default, file upload fields always include Content-Type in the request (non-file fields do not have Content-Type by default unless you supply it manually). If, for some reason, you don't want to use the Content-Type header in your request, then supply a blank Content-Type to exclude this header altogether (e.g., SomeFieldName.Content-Type=). In the example below, we have supplied Content-Type for file2 and SomeField1. All other fields are using the default content type. See the example below of uploading multiple files along with additional fields. If some API requires you to pass Content-Type: multipart/form-data rather than multipart/form-data, then manually set Request Header => Content-Type: multipart/mixed (it must start with multipart/ or it will be ignored). file1=@c:\data\Myfile1.txt file2=@c:\data\Myfile2.json file2.Content-Type=application/json SomeField1=aaaaaaa SomeField1.Content-Type=text/plain SomeField2=12345 SomeFieldWithNewLineAndTab=This is line1\r\nThis is line2\r\nThis is \ttab \ttab \ttab SomeFieldStartingWithAtSign=\@MyTwitterHandle
AddMultiPartPostamble Enable this option if your server is expecting
(i.e. CRLF) after last Multi-Part boundary in the Body. This option is only applicable if you enabled IsMultiPartUpload and sending data in Key=value format (i.e. Mutipart). For raw file upload this option has no effect.
EnableRequestCompression Enable this option if you like to compress request body (i.e. Content-Encoding: gzip). Enabling this option can speedup data transfer especially when you are sending large amount data (i.e. Upload file)
AllowAuthRedirectToAnyDomain By default when redirect happens (i.e. HTTP Code 301, 302, 307 and 308) to a different Host (domain or IP) then it removes the authorization header before redirecting to a new Host. If you trust the new host and you like to pass credentials after redirect then set this option. Without setting this option your HTTP request might fail.
SSIS Web API Destination - Setting UI
Articles
Click here to see all articles for [SSIS WEB API Destination] category
How to read YouTube API data in SSIS (Videos, Channels, Playlists)
Introduction In last few articles we saw how to read data from various Google Services. In this article we will see how to read YouTube API data in SSIS. This blog mainly focus on SSIS approach but steps mentioned to call Google APIs can be useful for any developer regardless which programming language or toolset […]
How to batch REST API requests in SSIS (Bulk Operation)
Introduction In our previous article we saw how to POST data to REST API using few different ways. Now let’s go one step further and discuss another common scenario to batch REST API requests in SSIS. For efficient data transfer many API provides you to submit multiple records in a single request. In this article […]
Read / Write Shopify data in SSIS (REST API)
Introduction In our previous article, we saw how to call REST API in SSIS. Now in let’s use that knowledge and learn how to read/write Shopify data in SSIS. If you are not aware of Shopify then its one of the most popular eCommerce platforms out there for small shops who sell online. Shopify provides […]
SSIS Magento data Read / Write using REST API Call
Introduction In this post we will lean SSIS Magento data read / write operations. Magento is a very popular eCommerce platform and they offer JSON based REST API and XML based SOAP API. You can use either API based on your need to automate common integration needs. We recommend using REST API (JSON API) if possible […]
SSIS Geocoding with Google Maps API
Introduction In this tutorial, we will cover the topics of how to perform geocoding on the addresses and reverse geocoding on the location coordinates using SSIS and Google Maps API. So what is geocoding, exactly? Geocoding is the process of translating an address (e.g. a street address) or a place to coordinates on the Earth’s surface. Simply […]
Read / Write Zoho CRM data using SSIS REST API Call
Introduction In this post, you will learn how to read / write Zoho CRM data using SSIS (Drag and drop approach without any coding).  We will use SSIS JSON/ REST API Source to extract data from Zoho API and use SSIS Web API Destination to write data to Zoho. We will look at step-by-step instructions to read Zoho CRM […]
Read / Write Smartsheet data using SSIS REST API Call
Introduction In this post you will learn how to Read / write Smartsheet data using SSIS (Drag and drop approach without any coding).  We will use SSIS JSON/ REST API Source to extract data from Smartsheet API and use SSIS Web API Destination to write data to Smartsheet. This approach is similar to our previous […]
Load SQL Server data to Workday using SSIS / SOAP API
Introduction In our previous article, we saw step-by-step approach to read data from workday using SSIS. In this article, we will focus on how to load SQL Server data to Workday (e.g. POST, Create, Update). We will use SSIS Web API Destination and the combination of other Transforms such as SSIS Template Transform and SSIS XML Generator […]
How to read / write data in Google BigQuery using SSIS
Introduction Google BigQuery is a fully managed Big Data platform to run queries against large scale data. In this article you will learn how to integrate Google BigQuery data into Microsoft SQL Server using SSIS. We will leverage highly flexible JSON based REST API Connector and OAuth Connection to import / export data from Google […]
Loading data from SQL Server to Elasticsearch with SSIS
Introduction Elasticsearch is a powerful engine that allows you to store, aggregate and, most importantly, search data in a very analytical way. In this tutorial, you will learn how to bulk load data from SQL Server to Elasticsearch with SSIS (part of SQL Server) and ZappySys PowerPack. The scope of this article will be to show how to import […]
