SSIS Secure FTP CSV Source can be used to parse / extract CSV files stored in secure ftp storage. You can also read compressed (gzip) files without extracting on local disk.
In this tutorial we will learn how to extract data from CSV file(In this case its from Secure FTP Server).
  2. Download and Install Local FTP/SFTP Rebex Tiny Sftp Server here.
  3. Once you finished above step, Open Visual Studio and Create New SSIS Package Project.
  4. Now, Drag and Drop SSIS Data Flow Task from SSIS Toolbox.
  5. Double click on the Data Flow task to see Data Flow designer surface.
  6. Here, In Visual Studio, drag and drop the ZS Secure FTP CSV Source in the design panel.
    SSIS Secure FTP CSV File Source - Drag and Drop
  7. In order to connect Secure SFTP server in SSIS, you will need obtain FTP/SFTP Credential.
How to create SFTP Server Connection.
  1. Right click on Connection Managers Panel to Create New SFTP Connection for Server, and Context Menu will appear, Select New Connection from the Context Menu.
    SFTP Task Operations - Connection
  2. Select ZS-SFTP Connection Manager from the Connection Managers list and Click on Add Button.
  3. Now in Connection Manager UI, Select SFTP - SSH File Transfer Protocol and Enter your Host name and Select Logon Type Username and Password and Enter it.
  4. Click on Test Connection. If test successful then hit OK to save the connection manager configure setting UI.
How to extract data from FTP server CSV File using Secure FTP CSV Source.
  1. Double click on ZS Secure FTP CSV File Source configure it.
  2. Select FTP Connection, Select file and check on First row has column headers.
    Example : You can download CSV Files from following url.
    http://zappysys.com/downloads/files/test/cust-1.csv
    http://zappysys.com/downloads/files/test/cust-2.csv
    http://zappysys.com/downloads/files/test/cust-3.csv
    SSIS Secure FTP CSV File Source - Configure
  4. Here you can setting in Advanced Tab for more settings.
    SSIS Secure FTP CSV File Source - Advanced Filter
  5. Lets see more settings for convert Date and Time, Just move in Date/Time Handling.
    SSIS Secure FTP CSV File Source - Date and Time Handling
  6. Click on OK button to save Secure FTP CSV Source configure setting UI.
  7. Now, Just Drag and Drop Our Free ZS Trash Destination from SSIS Toolbox.
  8. Now single click on the Secure Ftp CSV File Source, once you see blue arrow from source ... connect it to Trash Destination.
  9. Lets, double click on ZS Trash Destination to Configure it.
  10. Thats all, Just Run or Execute Package.
    SSIS Secure FTP CSV File Source - Execute
How to read data from FTP server CSV Zip File using Secure FTP CSV Source.
  2. Select connection and Zip file from source. Check on First row has column headers. You can download Zip/gz files from following URL.
    https://zappysys.com/downloads/files/test/invoices.csv.zip
    https://zappysys.com/downloads/files/test/invoices.csv.gz
  3. Now, in the compression tab, set file compression format to Zip(for only .zip file) or GZip(for only .gz file).
    SSIS Secure FTP CSV File Source - Compression Tab
  4. Click on Preview button to see Data Preview.
  5. Click on OK button to save Secure FTP CSV Source configure setting UI.
  6. Now, Just Drag and Drop Our Free ZS Trash Destination from SSIS Toolbox.
  7. Now single click on the Secure Ftp CSV File Source, once you see blue arrow from source ... connect it to Trash Destination.
  8. Lets, double click on ZS Trash Destination to Configure it.
  9. Thats all, Just Run or Execute Package.
ReplaceWith = ****$2
-OR-
ReplaceWith = ****${domain}
ColumnDelimiter Column delimiter for data you like to parse. To use custom delimiter type it directly or enter 4-digit hex string starting with \x (e.g. you can enter \x0009 for Tab character). For multiple characters repeat group. e.g. \x00090009 if you need two tabs.
HasColumnHeaderRow Column delimiter for data you like to parse.
ThrowErrorOnColumnCountMismatch Throw error if record has different number of columns than actual columns detected based on first row
ThrowErrorOnNoRecordFound Throw error if no record found or file is blank
AllowComment Allow comment lines which can be skipped by parser. When comment line found row is skipped. See CommentCharacter to configure first character for commented line.
CommentCharacter Allow lines with comment. When comment line found row is skipped. See LineCommentCharacter property to configure first character for commented line.
SkipRows Total data rows you like to skip (after header row)
SkipHeaderCommentRows Total rows you like to skip before header row. If its header less file then skip initial N rows (before any data row).
TreatBlankAsNull When this option is enabled, blank values for any column is treated as null so for string type rather than empty value you will see null value in the output.
IgnoreBlankLines When this option is enabled, blank lines are skipped.
SkipEmptyRecords When this option is enabled, any row with empty values in all fields is skipped (e.g. , , , , ).
TrimHeaders Trim column names if whitespace found before or after name
TrimFields Trim value for each field if whitespace found before or after
IgnoreQuotes Ignore quote character and consider it part of actual value
QuoteCharacter Quote character for quoted values.
None [0] None
GZip [1] GZip
Zip [2] Zip
TarGZip [3] TarGZip
None [0] Keep date as string
Auto [0] Auto
SSIS Secure FTP CSV File Source - Setting UI
