SSIS Dynamics CRM Destination can be used to perform bulk insert, update, delete and upsert operation on Microsoft Dynamics CRM Service such as Dynamics 365 Online or On-Premises installation.
In this tutorial we will learn how to import data into DynamicsCRM using ZS DynamicsCRM Destination(In this case its from OLE DB Source). Check this article for step-by-step instruction (Bulk Insert, Update, Delete, Upsert).
  5. Here, In Visual Studio, drag and drop the OLE DB Source and ZS DynamicsCRM Destination in the design surface and join the components with the blue arrow.
    SSIS DynamicsCRM Destination - Drag and Drop
  6. Lets create connection OLE DB Connection and DynamicsCRM Connection.
    SSIS OLEDB - Connection
How to Bulk Insert data into DynamicsCRM using DynamicsCRM Destination.
  1. Now, create table and insert couple of data for practice it use following text. You can replace table name.
    CREATE TABLE [dbo].[tbl_CRM_Accounts](
    	[AccountNumber] [varchar](50) NULL,
    	[AccountName] [varchar](50) NULL,
    	[City] [varchar](50) NULL,
    	[Country] [varchar](50) NULL
    ) ON [PRIMARY]
    INSERT INTO [dbo].[tbl_CRM_Accounts]([AccountNumber],[AccountName],[City],[Country])
    VALUES('10000001','TestAccount1','New York','USA')
    VALUES('10000002','TestAccount2','Mumbai','India')
    VALUES('10000003','TestAccount3','London','UK')
    VALUES('10000004','TestAccount4','Sydeny','Australia')
    VALUES('10000005','TestAccount5','Paris','USA')
  2. Double click on OLE DB Source to configure it.
  3. Lets Configure in Connection Manager, just follow below image steps.
  4. Click OK to Save OLEDB Source Editor UI Settings.
  5. Now, double click on DynamicsCRM Destination for configure it.
  6. In the connection manager select DynamicsCRM Connection we have created before.
    DynamicsCRM Destination - Connection Manager
  7. Here, in the Component Properties, set Operation to Insert and select TableName.
    DynamicsCRM Destination - Component Properties
  8. In the Column Mappings, map columns you want write data into DynamicsCRM Table.
    DynamicsCRM Destination - Columns Mappings
  9. Click on OK button to save DynamicsCRM Destination configure setting UI.
  10. Right click on blue arrow to Enable Data Viewer.
  11. Thats all, you can run or execute your package project and verify your data.
    DynamicsCRM Destination - Execute
How to Bulk Upsert(Update or Insert) data into DynamicsCRM using DynamicsCRM Destination.
  1. Double click on DynamicsCRM Destination for configure it.
  2. Here, in the Component Properties, set Operation to UpdateOrInsert and select TableName.
    DynamicsCRM Destination - Component Properties - Upsert
  3. In the Column Mappings, map columns you want write data into DynamicsCRM Table.
  4. Click on OK button to save DynamicsCRM Destination configure setting UI.
  5. Thats all, you can run or execute your package project and verify your data.
How to Bulk Delete data into DynamicsCRM using DynamicsCRM Destination.
  2. Here, in the Component Properties, set Operation to Delete and select TableName.
    DynamicsCRM Destination - Component Properties - Delete
How to Bulk Update data into DynamicsCRM using DynamicsCRM Destination.
  2. Here, in the Component Properties, set Operation to Update and select TableName.
    DynamicsCRM Destination - Component Properties - Update
Operation Action you like to perform
Insert [0] Insert
Update [1] Update
UpdateOrInsert [2] UpdateOrInsert
Delete [3] Delete
UpsertKeyField Update / Upsert Key Field name. Enter Primary Key or Alternate Key. Alternate key field based on which you want to perform Upsert action (this field must be mapped on column mappings). Here is how you can define Alternate Key for an entity (i.e. Table) https://technet.microsoft.com/library/29e53691-0b18-4fde-a1d0-7490aa227898.aspx or https://msdn.microsoft.com/en-us/library/dn932139.aspx
UseDefaultIfLookupFails Use default value (or null value) when text to id lookup fails for any entity lookup or OptionSet (drop down style value)
EnableDuplicateDetection Set this to true if you do not want to allow duplicate records during the Insert, Upsert, or Update operation (By default, duplicate records are allowed). After setting this option to true, you must test the process to see Duplicate detection rule is triggered correctly or not. Depending on which entity you choose you may or may not have the duplicate detection rule set, some entities like accounts, contacts, and leads may already have this type of rule setup but not other entities (Check your Duplicate Detection Rules in the entity if duplicate detection fails). Behind the scene setting this EnableDuplicateDetection=true sends SuppressDuplicateDetection=false in the CRM API call.
SolutionUniqueName A String that specifies the unique name of the solution to which the operation applies. .
DoNotCreateOutputs Enable / Disable Response Output. Checking this option can remove unwanted warnings about unused Columns and many times speedup performance so if output is not needed set this option to True so its removed.
TableName Target object name where you want like to write data.
BatchSize How many rows you want to send in each request.
IgnoreFieldsIfInputNull Set this option to True if you wish to ignore fields if input value is NULL. By default target field is set to NULL if input value is NULL.
FieldsToSetNullIfInputNull Comma separated CRM entity field names which you like to set as NULL when input value is NULL. This option is ignored if IgnoreFieldsIfInputNull is not set to True.
EnableParallelProcessing Enables sending requests using multiple threads to speed up processing. Try to adjust MaxParallelThreads property to test performance gain. This property is ignored if you EnableBulkMode=true.
MaxParallelThreads Max Parallel Threads to use to process requests. This property is only valid if you set EnableParallelProcessing=True. Valid values are 1 to 40. This property is ignored if you EnableBulkMode=true.
InputDateTimeConversionMode Specifies how to convert input DateTime / DateTimeOffset values before writing to CRM (TFS10537/TFS10539). None = preserve DateTime Kind (do not invent UTC Z). LocalToUtc = convert local/unspecified to UTC. UtcToLocal = convert UTC to local. FormatISO = legacy compatibility: append Z without converting (previous buggy behavior for packages that already compensated for the old shift).
None [0] Default
UtcToLocal [1] Output As Local Time
LocalToUtc [2] Output As UTC Time
FormatISO [3] Output As ISO format
DynamicsCRM Destination - Setting UI
Handling Special DataTypes (PickList, Lookup, PartyList)
Dynamics CRM supports many datatypes which can be handled without any issue in ZappySys CRM Destination. However following three datatypes (i.e. PickList, Lookup, PartyList) require special handling when you insert/update or upsert.
1. PickList DataType
PickList datatype is simple dropddown style datatype which provides selection of predefined options (Enum in Programming Language) where user selects Text and behind the scene it stores the Numeric value for selection. In CRM Destination you can set PickList field by Text or Numeric value. If you use Text as input then any non matching entry will result into error. If you wish to ignore errors and insert as null then set UseDefaultIfLookupFails option
2. Lookup DataType
Lookup datatype allows to refer record from different table just like foreign key in relational database. Here are some important point about this datatype. Now lets review few ways to pass input data for Lookup datatype. You can use any of the following format as your input data.
  1. Text format - Id Lookup:
    You can set Lookup field using following simple input format (key/value pair). Id is related record Id from different table. Type is related record type (i.e. account, lead, contact). Type is optional so if you don't specify it then first allowed type will be assumed in alphabetical order (e.g. account).
    Syntax:
    RECORD_ID[=TYPE_NAME];
    Examples:
    0fe3ac7c-d63d-e811-a953-000d3a37468c
    --OR--
    0fe3ac7c-d63d-e811-a953-000d3a37468c=account
  2. JSON format - Id Lookup:
    You can also use JSON Format as your input data to set Lookup type field. Where RECORD_ID is related record Id from different table. Type is related record type (i.e. account, lead, contact). Type is optional so if you don't specify it then first allowed type will be assumed in alphabetical order (e.g. account).
    Syntax:
    [{"id":"RECORD_ID" ,"type":"RECORD_TYPE"}]​
    Examples:
    [{"id":"0fe3ac7c-d63d-e811-a953-000d3a37468c"}]​
    --OR--
    [{"id":"0fe3ac7c-d63d-e811-a953-000d3a37468c", "type":"account"}]​
  3. JSON format - Text Lookup (**SLOW** - Local Caching Needed):
    You can also use JSON Format to lookup by Text rather than Id. However this approach can be very slow if you are doing lookup against very large entity so use Text Lookup only if necessary.
    text is related record's primary field value (if field is not supplied) --OR-- value of the field name you supplied.
    field is name of column (e.g. firstname) on which you like to perform lookup. If you don't specify field in your json then PrimaryNameAttribute will be used to determine field name. Use Dynamics CRM Source FetchXML mode and on the Object Browser goto Table Info tab to find PrimaryNameAttribute to determine primary name field for selected entity.
    Syntax:
    [{"text":"VALUE" ,"type":"LOOKUP_RECORD_TYPE","field":"LOOKUP_FIELD_NAME"}]​
    Examples:
    [{"text":"ZappySys"}]​
    --OR--
    [{"text": "ZappySys", "type": "account"}]​
    --OR--
    [{"text": "ZappySys", "type": "account", "field": "name"}]​
3. PartyList DataType
Certain entities like Appointment support special type of fields for (e.g. requiredattendees) which can hold reference to multiple records from multiple tables. Here are some important point about this datatype. Now lets review few ways to pass input data for PartyList datatype. You can use any of the following format as your input data.
    You can set PartyList field using following simple input format (key/value pairs). Id is related record Id from different table. Type is related record type (i.e. account, lead, contact). Type is optional so if you don't specify it then first allowed type will be assumed in alphabetical order (e.g. account).
    Syntax:
    RECORD_ID_1[=TYPE_NAME];RECORD_ID_2[=TYPE_NAME];....RECORD_ID_N[=TYPE_NAME];
    Examples:
    --OR--
    0fe3ac7c-d63d-e811-a953-000d3a37468c;6329dbd0-4e1c-e511-80d3-3863bb347ba8=lead
    --OR--
    0fe3ac7c-d63d-e811-a953-000d3a37468c=account;6329dbd0-4e1c-e511-80d3-3863bb347ba8=lead
    You can also use JSON Format as your input data to set PartyList field. Where RECORD_ID is related record Id from different table. Type is related record type (i.e. account, lead, contact). Type is optional so if you don't specify it then first allowed type will be assumed in alphabetical order (e.g. account).
    Syntax:
    [{"id":"RECORD_ID_1" ,"type":"RECORD_TYPE"}, {"id":"RECORD_ID_2" ,"type":"RECORD_TYPE"} ... {"id":"RECORD_ID_N" ,"type":"RECORD_TYPE"}]​
    Examples:
    --OR--
    --OR--
    [{"id":"0fe3ac7c-d63d-e811-a953-000d3a37468c"}, {"type":"lead","id":"6329dbd0-4e1c-e511-80d3-3863bb347ba8"}]​
    --OR--
    [{"id":"0fe3ac7c-d63d-e811-a953-000d3a37468c", "type":"account"}, {"type":"lead","id":"6329dbd0-4e1c-e511-80d3-3863bb347ba8"}]​
    You can also use JSON Format as to lookup by Text rather than Id. However this approach can be very slow if you are doing lookup against very large entity so use Text Lookup only if necessary.
    Syntax:
    [{"text":"VALUE_1" ,"type":"LOOKUP_RECORD_TYPE","field":"LOOKUP_FIELD_NAME"}, {"id":"VALUE_2" ,"type":"LOOKUP_RECORD_TYPE","field":"LOOKUP_FIELD_NAME"} ... {"text":"VALUE_N" ,"type":"RECORD_TYPE","field":"LOOKUP_FIELD_NAME"}]​
    Examples:
    --OR--
    --OR--
    --OR--
    [{"text": "ZappySys", "type": "account", "field": "name"}, {"text": "Bob Smith", "type": "lead", "field": "fullname"}] ​
    --OR--
    [{"text": "ZappySys", "type": "account"}, {"text": "Bob Smith", "type": "lead", "field": "fullname"}] ​
Click here to see all articles for [SSIS Dynamics CRM Destination] category
SSIS PowerPack v2.9.5 released (Maintenance Release)
What’s New In this release we focused on fixing some bugs with Dynamics CRM Source , Dynamics CRM Destination and Reporting Services Task. Version 2.9.6.10621 [Jun 24, 2019] New Features/Improvements NEW: Excel Source – Add option to read from any sheet by number rather than hard coded table name (e.g. $4$ , $5$ … ) Bug fixes […]
Load data into Dynamics CRM using SSIS – Insert, Upsert, Delete, Update
Introduction In our previous article, we talked about how to read from Dynamics CRM. Now let’s look at how to Load data into Dynamics CRM using SSIS. We will see a few important aspects of loading data into Dynamics CRM Online (i.e. Dynamics 365) and On-premises / IFD (Internet facing hosted instance). We will show you how to […]
