	<title>SSIS Power Archives | ZappySys Blog</title>
	<atom:link href="https://zappysys.com/blog/tag/ssis-power/feed/" rel="self" type="application/rss+xml" />
	<link>https://zappysys.com/blog/tag/ssis-power/</link>
	<lastBuildDate>Mon, 18 May 2026 15:39:18 +0000</lastBuildDate>
		<title>How to upload files on SharePoint Online using SSIS</title>
		<link>https://zappysys.com/blog/upload-files-sharepoint-online-using-ssis/</link>
		<pubDate>Fri, 29 Dec 2023 12:49:39 +0000</pubDate>
				<category><![CDATA[SSIS API Source]]></category>
		<category><![CDATA[Foreach Loop Container]]></category>
		<category><![CDATA[sharepoint online]]></category>
		<category><![CDATA[ssis advanced file system task]]></category>
		<category><![CDATA[SSIS Power]]></category>
		<category><![CDATA[SSIS SharePoint Online Connector]]></category>
		<guid isPermaLink="false">https://zappysys.com/blog/?p=10902</guid>
					<description><![CDATA[<p>Introduction If you need to upload files from SSIS to SharePoint Online, the ZappySys SharePoint Online Connector for SSIS gives you a direct way to configure the connection, authenticate, and send files without building the API calls from scratch. This guide shows how to upload one file or multiple files to SharePoint Online using SSIS, [&#8230;]</p>
<p>The post <a href="https://zappysys.com/blog/upload-files-sharepoint-online-using-ssis/">How to upload files on SharePoint Online using SSIS</a> appeared first on <a href="https://zappysys.com/blog">ZappySys Blog</a>.</p>
										<content:encoded><![CDATA[<h2><strong>Introduction</strong></h2>
<p><a href="https://zappysys.com/blog/wp-content/uploads/2018/05/sharepoint-icon.jpg"><img loading="lazy" decoding="async" class="wp-image-3731 alignleft" src="https://zappysys.com/blog/wp-content/uploads/2018/05/sharepoint-icon.jpg" alt="sharepoint icon" width="100" height="100" srcset="https://zappysys.com/blog/wp-content/uploads/2018/05/sharepoint-icon.jpg 225w, https://zappysys.com/blog/wp-content/uploads/2018/05/sharepoint-icon-150x150.jpg 150w" sizes="(max-width: 100px) 100vw, 100px" /></a>If you need to upload files from SSIS to SharePoint Online, the ZappySys <a href="https://zappysys.com/api/integration-hub/sharepoint-connector/ssis">SharePoint Online Connector for SSIS</a> gives you a direct way to configure the connection, authenticate, and send files without building the API calls from scratch.</p>
<p>This guide shows how to upload one file or multiple files to SharePoint Online using SSIS, API Source, and supporting SSIS components.</p>
</ol></div>
<h2>Upload files to SharePoint Online with SSIS</h2>
<p>In this section, you will configure the SharePoint Online Connector in API Source and use it to upload files to SharePoint Online.</p>
<li>Begin by opening Visual Studio and creating a new project.</li>
<li>Select Integration Service Project and in the new project window set the appropriate name and location for the project. Click OK.</li>
<li>In the new SSIS project screen you will find the following:
<ol style="list-style-type: lower-alpha;">
<li>SSIS ToolBox on the left sidebar</li>
<li>Solution Explorer and Property Window on the right bar</li>
<li>Control flow, data flow, event Handlers, Package Explorer in tab windows</li>
<li>Connection Manager Window at the bottom</li>
<div id="attachment_10258" style="width: 710px" class="wp-caption alignnone"><a href="https://zappysys.com/blog/upload-files-google-drive-using-ssis/zappysys-ssis-project-with-toolbox/#main"><img loading="lazy" decoding="async" aria-describedby="caption-attachment-10258" class="wp-image-10258" src="https://zappysys.com/blog/wp-content/uploads/2023/08/zappysys-ssis-project-with-toolbox-1024x653.png" alt="zappysys ssis project with toolbox" width="700" height="447" srcset="https://zappysys.com/blog/wp-content/uploads/2023/08/zappysys-ssis-project-with-toolbox-1024x653.png 1024w, https://zappysys.com/blog/wp-content/uploads/2023/08/zappysys-ssis-project-with-toolbox-300x191.png 300w, https://zappysys.com/blog/wp-content/uploads/2023/08/zappysys-ssis-project-with-toolbox-768x490.png 768w, https://zappysys.com/blog/wp-content/uploads/2023/08/zappysys-ssis-project-with-toolbox.png 1287w" sizes="(max-width: 700px) 100vw, 700px" /></a><p id="caption-attachment-10258" class="wp-caption-text">SSIS Toolbox &#8211; ZappySys Tasks</p></div>
<div class="su-note"  style="border-color:#e5dd9d;border-radius:3px;-moz-border-radius:3px;-webkit-border-radius:3px;"><div class="su-note-inner su-u-clearfix su-u-trim" style="background-color:#fff7b7;border-color:#ffffff;color:#333333;border-radius:3px;-moz-border-radius:3px;-webkit-border-radius:3px;"><strong>NOTE</strong>: If you don&#8217;t see ZappySys SSIS PowerPack Task or Components in the SSIS Toolbox, please refer to <a href="https://zappysys.zendesk.com/hc/en-us/articles/115004935754-I-don-t-see-PowerPack-components-in-SSIS-Toolbox">this help link</a>.</div></div></li>
<li>Drag and drop the SSIS Data Flow Task from the SSIS Toolbox. Double-click on the Data Flow Task to see the Data Flow Designer.<br />
<a href="https://zappysys.com/blog/wp-content/uploads/2023/08/drag-and-drop-data-flow-task.png"><img loading="lazy" decoding="async" class="alignnone size-full wp-image-10260" src="https://zappysys.com/blog/wp-content/uploads/2023/08/drag-and-drop-data-flow-task.png" alt="" width="460" height="155" srcset="https://zappysys.com/blog/wp-content/uploads/2023/08/drag-and-drop-data-flow-task.png 460w, https://zappysys.com/blog/wp-content/uploads/2023/08/drag-and-drop-data-flow-task-300x101.png 300w" sizes="(max-width: 460px) 100vw, 460px" /></a></li>
<li>From the SSIS Toolbox, drag and drop API Source (Predefined Templates) onto the Data Flow Designer surface, then double-click it to edit it:<br />
<a href="https://zappysys.com/blog/wp-content/uploads/2023/08/ssis-api-source-drag-and-drop.jpg"><img loading="lazy" decoding="async" class="alignnone size-full wp-image-10262" src="https://zappysys.com/blog/wp-content/uploads/2023/08/ssis-api-source-drag-and-drop.jpg" alt="" width="659" height="292" srcset="https://zappysys.com/blog/wp-content/uploads/2023/08/ssis-api-source-drag-and-drop.jpg 659w, https://zappysys.com/blog/wp-content/uploads/2023/08/ssis-api-source-drag-and-drop-300x133.jpg 300w" sizes="(max-width: 659px) 100vw, 659px" /></a></li>
<li>Select <strong>New Connection</strong> to create a new connection:<br />
<a href="https://zappysys.com/blog/wp-content/uploads/2023/08/ssis-api-source-new-connection.png"><img loading="lazy" decoding="async" class="alignnone size-full wp-image-10263" src="https://zappysys.com/blog/wp-content/uploads/2023/08/ssis-api-source-new-connection.png" alt="" width="684" height="643" srcset="https://zappysys.com/blog/wp-content/uploads/2023/08/ssis-api-source-new-connection.png 684w, https://zappysys.com/blog/wp-content/uploads/2023/08/ssis-api-source-new-connection-300x282.png 300w" sizes="(max-width: 684px) 100vw, 684px" /></a></li>
<h2>Configuring the SharePoint Online Connector</h2>
<li>Use a preinstalled SharePoint Online Connector from the Popular Connector List or press the Search Online radio button to download SharePoint Online Connector. Once downloaded simply use it in the configuration:
<div id="attachment_10888" style="width: 876px" class="wp-caption alignnone"><a href="https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-template-selection-sharepoint-walkthrough.png"><img loading="lazy" decoding="async" aria-describedby="caption-attachment-10888" class="wp-image-10888 size-full" src="https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-template-selection-sharepoint-walkthrough.png" alt="SSIS ZS API Connection Manager - Select SharePoint Online Connector" width="866" height="773" srcset="https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-template-selection-sharepoint-walkthrough.png 866w, https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-template-selection-sharepoint-walkthrough-300x268.png 300w, https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-template-selection-sharepoint-walkthrough-768x686.png 768w" sizes="(max-width: 866px) 100vw, 866px" /></a><p id="caption-attachment-10888" class="wp-caption-text">SSIS ZS API Connection Manager &#8211; Select SharePoint Online Connector</p></div></li>
<li>Select the desired authentication type. Then choose the API Base URL. In most cases, the default value is correct. Fill in the required parameters and add optional parameters only when needed.</li>
<li>After configuring the required properties in API Connection Manager, click <strong>Test Connection</strong> to confirm that the connection works.<br />
<h3>Method 1: Connect to SharePoint Online using user credentials [OAuth]</h3>
<p>Use the <a href="https://zappysys.com/api/integration-hub/sharepoint-connector/help/authentication/UserCreds"><strong>Steps to Configure</strong></a> link to help set the required parameters.</p>
<div id="attachment_10884" style="width: 876px" class="wp-caption alignnone"><a href="https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-api-source-sharepoint-generate-token-user-credentials.png"><img loading="lazy" decoding="async" aria-describedby="caption-attachment-10884" class="wp-image-10884 size-full" src="https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-api-source-sharepoint-generate-token-user-credentials.png" alt="SSIS ZS API Connection Manager - Generate Token - SharePoint Online with User Credentials" width="866" height="814" srcset="https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-api-source-sharepoint-generate-token-user-credentials.png 866w, https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-api-source-sharepoint-generate-token-user-credentials-300x282.png 300w, https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-api-source-sharepoint-generate-token-user-credentials-768x722.png 768w" sizes="(max-width: 866px) 100vw, 866px" /></a><p id="caption-attachment-10884" class="wp-caption-text">SSIS ZS API Connection Manager &#8211; Generate Token &#8211; SharePoint Online with User Credentials</p></div>
<h3>Method 2: Connect to SharePoint Online using application credentials [OAuth]</h3>
<p>Use the <a href="https://zappysys.com/api/integration-hub/sharepoint-connector/help/authentication/AppCreds"><strong>Steps to Configure</strong></a> link to help set the required parameters.</p>
<div id="attachment_10892" style="width: 876px" class="wp-caption alignnone"><a href="https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-api-source-sharepoint-application-creds-generate-token.png"><img loading="lazy" decoding="async" aria-describedby="caption-attachment-10892" class="size-full wp-image-10892" src="https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-api-source-sharepoint-application-creds-generate-token.png" alt="SSIS API Source - Generate Token - SharePoint Online with Application Credentials" width="866" height="773" srcset="https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-api-source-sharepoint-application-creds-generate-token.png 866w, https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-api-source-sharepoint-application-creds-generate-token-300x268.png 300w, https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-api-source-sharepoint-application-creds-generate-token-768x686.png 768w" sizes="(max-width: 866px) 100vw, 866px" /></a><p id="caption-attachment-10892" class="wp-caption-text">SSIS API Source &#8211; Generate Token &#8211; SharePoint Online with Application Credentials</p></div></li>
<h2>How to upload a local file to SharePoint Online</h2>
<p>In the API Source Component, we&#8217;ve chosen the API Connection Manager. Next, we need to configure the remaining properties of the component to upload a local file to SharePoint Online.</p>
<li>Choose the <strong>Upload file</strong> endpoint from the &#8220;Select Table/Endpoint&#8221; dropdown menu.</li>
<li>Select the desired Drive ID from the <strong>DriveId</strong> drop-down.</li>
<li>Specify the desired source file path for the file being uploaded by setting the <strong>DiskFilePath</strong> parameter.</li>
<li>Specify the desired Target Path by setting the <strong>SharePointFilePath</strong> parameter.</li>
<p>Please refer to the sample screenshot below.</p>
<div id="attachment_10906" style="width: 1010px" class="wp-caption alignnone"><a href="https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-api-source-sharepoint-single-file-upload-1.png"><img loading="lazy" decoding="async" aria-describedby="caption-attachment-10906" class="wp-image-10906" src="https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-api-source-sharepoint-single-file-upload-1-1024x569.png" alt="SSIS API Source – SharePoint Online – Upload Single File" width="1000" height="555" srcset="https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-api-source-sharepoint-single-file-upload-1-1024x569.png 1024w, https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-api-source-sharepoint-single-file-upload-1-300x167.png 300w, https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-api-source-sharepoint-single-file-upload-1-768x426.png 768w, https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-api-source-sharepoint-single-file-upload-1.png 1410w" sizes="(max-width: 1000px) 100vw, 1000px" /></a><p id="caption-attachment-10906" class="wp-caption-text">SSIS API Source – SharePoint Online – Upload Single File</p></div>
<p>After configuring the properties above, click <strong>Preview Data</strong> to test the API call. At this point, the SharePoint Online Connector is ready to upload a local file from SSIS.</p>
<h2>How to upload multiple files to SharePoint Online</h2>
<p>In the API Source Component, we&#8217;ve selected the API Connection Manager. Next, we need to configure the remaining properties of the component to upload multiple files to SharePoint Online. Additionally, we should utilize a Foreach Loop Container to iterate through each file one by one in a loop.</p>
<li>Create 3 SSIS variables as described below.<br />
<table border="1">
<tbody>
<tr>
<th>Variable Name</th>
<th>Datatype</th>
<th>Value</th>
</tr>
<tr>
<td>varFileLists</td>
<td>Object</td>
<td>System.Object</td>
</tr>
<tr>
<td>varFileName</td>
<td>String</td>
<td>fake.extension</td>
</tr>
<tr>
<td>varFullFilePath</td>
<td>String</td>
<td>C:/fake/fake.extension</td>
</tr>
</tbody>
</table>
<li>Go to Control Flow, From the SSIS toolbox drag and drop <strong>ZS Advanced File System Task</strong> on the control flow designer surface, and double click on it to edit it:<br />
<a href="https://zappysys.com/blog/wp-content/uploads/2023/09/ssis-advanced-file-system-task-drag-and-drop.png"><img loading="lazy" decoding="async" class="alignnone size-full wp-image-10363" src="https://zappysys.com/blog/wp-content/uploads/2023/09/ssis-advanced-file-system-task-drag-and-drop.png" alt="SSIS Advanced File System Task - Drag &amp; Drop" width="580" height="241" srcset="https://zappysys.com/blog/wp-content/uploads/2023/09/ssis-advanced-file-system-task-drag-and-drop.png 580w, https://zappysys.com/blog/wp-content/uploads/2023/09/ssis-advanced-file-system-task-drag-and-drop-300x125.png 300w" sizes="(max-width: 580px) 100vw, 580px" /></a></li>
<li>Select the &#8220;Get file list as ADO.NET Data Table&#8221; action from the Action drop-down menu. Set the file path in the Path textbox. Choose the variable (Object type) where you want to store the file list, and then click the OK button to save the settings.
<div id="attachment_10364" style="width: 722px" class="wp-caption alignnone"><a href="https://zappysys.com/blog/wp-content/uploads/2023/09/ssis-advanced-file-system-task-store-filelists-adotable-in-object-variable.png"><img loading="lazy" decoding="async" aria-describedby="caption-attachment-10364" class="size-full wp-image-10364" src="https://zappysys.com/blog/wp-content/uploads/2023/09/ssis-advanced-file-system-task-store-filelists-adotable-in-object-variable.png" alt="SSIS Advanced File System Task - Get file list as ADO.net Data Table" width="712" height="623" srcset="https://zappysys.com/blog/wp-content/uploads/2023/09/ssis-advanced-file-system-task-store-filelists-adotable-in-object-variable.png 712w, https://zappysys.com/blog/wp-content/uploads/2023/09/ssis-advanced-file-system-task-store-filelists-adotable-in-object-variable-300x263.png 300w" sizes="(max-width: 712px) 100vw, 712px" /></a><p id="caption-attachment-10364" class="wp-caption-text">SSIS Advanced File System Task &#8211; Get file list as ADO.net Data Table</p></div></li>
<li>Now, drag and drop the &#8220;Foreach Loop Container&#8221; from the SSIS Toolbox and connect it with the &#8220;ZS Advanced File System Task.&#8221; Double-click on the &#8220;Foreach Loop Container&#8221; to edit its properties.
<div id="attachment_10365" style="width: 750px" class="wp-caption alignnone"><a href="https://zappysys.com/blog/wp-content/uploads/2023/09/ssis-foreach-loop-container-drag-and-drop-googledrive.png"><img loading="lazy" decoding="async" aria-describedby="caption-attachment-10365" class="size-full wp-image-10365" src="https://zappysys.com/blog/wp-content/uploads/2023/09/ssis-foreach-loop-container-drag-and-drop-googledrive.png" alt="SSIS Foreach Loop Container - Drag &amp; Drop" width="740" height="531" srcset="https://zappysys.com/blog/wp-content/uploads/2023/09/ssis-foreach-loop-container-drag-and-drop-googledrive.png 740w, https://zappysys.com/blog/wp-content/uploads/2023/09/ssis-foreach-loop-container-drag-and-drop-googledrive-300x215.png 300w" sizes="(max-width: 740px) 100vw, 740px" /></a><p id="caption-attachment-10365" class="wp-caption-text">SSIS Foreach Loop Container &#8211; Drag &amp; Drop</p></div></li>
<li>In the Foreach Loop Editor&#8217;s &#8220;Collection&#8221; tab, choose the Enumerator as &#8220;Foreach ADO Enumerator.&#8221; In the &#8220;ADO object source variable&#8221; field, select your SSIS object-typed variable. Select the &#8220;Rows in the first table&#8221; radio option.
<div id="attachment_10371" style="width: 747px" class="wp-caption alignnone"><a href="https://zappysys.com/blog/wp-content/uploads/2023/09/ssis-googledrive-multiplefiles-upload-foreach-loop-editor-collection-tab-configuration.png"><img loading="lazy" decoding="async" aria-describedby="caption-attachment-10371" class="size-full wp-image-10371" src="https://zappysys.com/blog/wp-content/uploads/2023/09/ssis-googledrive-multiplefiles-upload-foreach-loop-editor-collection-tab-configuration.png" alt="SSIS Foreach Loop Editor - Collection - Select Variable &amp; Enumeration mode" width="737" height="631" srcset="https://zappysys.com/blog/wp-content/uploads/2023/09/ssis-googledrive-multiplefiles-upload-foreach-loop-editor-collection-tab-configuration.png 737w, https://zappysys.com/blog/wp-content/uploads/2023/09/ssis-googledrive-multiplefiles-upload-foreach-loop-editor-collection-tab-configuration-300x257.png 300w" sizes="(max-width: 737px) 100vw, 737px" /></a><p id="caption-attachment-10371" class="wp-caption-text">SSIS Foreach Loop Editor &#8211; Collection &#8211; Select Variable &amp; Enumeration mode</p></div></li>
<li>In the Foreach Loop Editor&#8217;s &#8220;Variable Mappings&#8221; tab, select the variables that you want to map to the values from the collection, and then click the &#8220;OK&#8221; button to save your selections.
<div id="attachment_10370" style="width: 747px" class="wp-caption alignnone"><a href="https://zappysys.com/blog/wp-content/uploads/2023/09/ssis-googledrive-multiplefiles-upload-foreach-loop-editor-variablemappings.png"><img loading="lazy" decoding="async" aria-describedby="caption-attachment-10370" class="size-full wp-image-10370" src="https://zappysys.com/blog/wp-content/uploads/2023/09/ssis-googledrive-multiplefiles-upload-foreach-loop-editor-variablemappings.png" alt="SSIS Foreach Loop Editor - Variable Mappings tab" width="737" height="631" srcset="https://zappysys.com/blog/wp-content/uploads/2023/09/ssis-googledrive-multiplefiles-upload-foreach-loop-editor-variablemappings.png 737w, https://zappysys.com/blog/wp-content/uploads/2023/09/ssis-googledrive-multiplefiles-upload-foreach-loop-editor-variablemappings-300x257.png 300w" sizes="(max-width: 737px) 100vw, 737px" /></a><p id="caption-attachment-10370" class="wp-caption-text">SSIS Foreach Loop Editor &#8211; Variable Mappings</p></div></li>
<li>Inside the Foreach Loop Container, drag and drop the Data Flow Task, and then rename it according to your preference.
<div id="attachment_10854" style="width: 830px" class="wp-caption alignnone"><a href="https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-dataflow-task-inside-foreachloop-container-multiplefiles-upload.png"><img loading="lazy" decoding="async" aria-describedby="caption-attachment-10854" class="size-full wp-image-10854" src="https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-dataflow-task-inside-foreachloop-container-multiplefiles-upload.png" alt="SSIS Data Flow Task - Drag &amp; Drop inside Foreach Loop Container" width="820" height="428" srcset="https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-dataflow-task-inside-foreachloop-container-multiplefiles-upload.png 820w, https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-dataflow-task-inside-foreachloop-container-multiplefiles-upload-300x157.png 300w, https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-dataflow-task-inside-foreachloop-container-multiplefiles-upload-768x401.png 768w" sizes="(max-width: 820px) 100vw, 820px" /></a><p id="caption-attachment-10854" class="wp-caption-text">SSIS Data Flow Task &#8211; Drag &amp; Drop inside Foreach Loop Container</p></div></li>
<li>Double-click on the Data Flow Task to see the Data Flow Designer, From the SSIS Toolbox, drag and drop API Source (Predefined Templates) onto the Data Flow Designer surface, then double-click it to edit it:<br />
<a href="https://zappysys.com/blog/wp-content/uploads/2023/08/ssis-api-source-drag-and-drop.jpg"><img loading="lazy" decoding="async" class="alignnone size-full wp-image-10262" src="https://zappysys.com/blog/wp-content/uploads/2023/08/ssis-api-source-drag-and-drop.jpg" alt="SSIS API Source - Drag &amp; Drop" width="659" height="292" srcset="https://zappysys.com/blog/wp-content/uploads/2023/08/ssis-api-source-drag-and-drop.jpg 659w, https://zappysys.com/blog/wp-content/uploads/2023/08/ssis-api-source-drag-and-drop-300x133.jpg 300w" sizes="(max-width: 659px) 100vw, 659px" /></a></li>
<li>Double-click on the <strong>API Source</strong> component to configure it for uploading multiple files to SharePoint Online.
<li>Set the <strong>SharePointFilePath</strong> parameter to the SSIS variable that contains the file name, such as <strong>varFileName</strong>.</li>
<li>Set the <strong>DiskFilePath</strong> parameter to the SSIS variable that contains the local file path, such as <strong>varFullFilePath</strong>.<br />
When configuring the SSIS variable directly in the Raw Edit, JSON may become invalid due to the requirement of slashes within the local file path. To address this, we use a JSONENC Placeholder Function for proper escaping.<br />
<pre class="crayon-plain-tag">&lt;&lt;{{User::varUserFullFilePath}},FUN_JSONENC&gt;&gt;</pre></li>
<li>If you wish to upload the local file to a specific folder in SharePoint Online, please set the folderName in the <strong>SharePointFilePath </strong>parameter.</li>
<div id="attachment_10904" style="width: 896px" class="wp-caption alignnone"><a href="https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-api-source-sharepoint-multiple-files-upload.png"><img loading="lazy" decoding="async" aria-describedby="caption-attachment-10904" class="size-full wp-image-10904" src="https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-api-source-sharepoint-multiple-files-upload.png" alt="SSIS API Source – SharePoint Online – Upload Multiple files configuration" width="886" height="603" srcset="https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-api-source-sharepoint-multiple-files-upload.png 886w, https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-api-source-sharepoint-multiple-files-upload-300x204.png 300w, https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-api-source-sharepoint-multiple-files-upload-768x523.png 768w" sizes="(max-width: 886px) 100vw, 886px" /></a><p id="caption-attachment-10904" class="wp-caption-text">SSIS API Source – SharePoint Online – Upload Multiple files configuration</p></div>
<p>To configure dynamic filenames and file paths, you can set variables. Click on &#8220;Raw Edit,&#8221; and in the &#8220;Edit Parameters&#8221; popup, you can use SSIS variables, as shown in the above image.</p>
<p>Once you have configured all the mentioned properties above, please click on the &#8220;Preview Data&#8221; button to initiate the API call.<br />
After that, execute the SSIS package and confirm that the files are uploaded to SharePoint Online. The screenshot below shows a sample result.</p>
<div id="attachment_10905" style="width: 1010px" class="wp-caption alignnone"><a href="https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-uploaded-multiple-files-sharepoint.png"><img loading="lazy" decoding="async" aria-describedby="caption-attachment-10905" class="wp-image-10905" src="https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-uploaded-multiple-files-sharepoint-1024x465.png" alt="Multiple files uploaded on SharePoint Online using SSIS" width="1000" height="454" srcset="https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-uploaded-multiple-files-sharepoint-1024x465.png 1024w, https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-uploaded-multiple-files-sharepoint-300x136.png 300w, https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-uploaded-multiple-files-sharepoint-768x349.png 768w, https://zappysys.com/blog/wp-content/uploads/2023/12/ssis-uploaded-multiple-files-sharepoint.png 1262w" sizes="(max-width: 1000px) 100vw, 1000px" /></a><p id="caption-attachment-10905" class="wp-caption-text">Multiple files uploaded on SharePoint Online using SSIS</p></div>
<p>You have now configured the SharePoint Online Connector to upload multiple files from SSIS.</li>
<p>In this guide, you learned how to connect to SharePoint Online using SSIS API Connection Manager and upload one or many files using the <a href="https://zappysys.com/products/ssis-powerpack/ssis-api-source/">SSIS API Source component</a>, <a href="https://zappysys.com/products/ssis-powerpack/ssis-file-system-task-advanced/">SSIS ZS Advanced File System Task</a>, Foreach Loop Container, and SSIS variables.</p>
<h2>Frequently Asked Questions</h2>
<h3>Can I upload more than one file to SharePoint Online from SSIS</h3>
<p>Yes. You can use a Foreach Loop Container with SSIS variables and ZS Advanced File System Task to iterate through a file list and upload files one by one.</p>
<h3>What is the easiest way to upload files to SharePoint Online from SSIS</h3>
<p>The simplest approach is to use the <a href="https://zappysys.com/api/integration-hub/sharepoint-connector/ssis">SharePoint Online Connector for SSIS</a>, because it provides ready-made authentication and upload endpoints inside the ZappySys connector interface.</p>
<h3>Which component uploads the files</h3>
<p>The upload action is configured in API Source by selecting the <strong>Upload file</strong> endpoint and setting values such as <strong>DriveId</strong>, <strong>DiskFilePath</strong>, and <strong>SharePointFilePath</strong>.</p>
<h2>Next step</h2>
<p>If you want to build this workflow in your own SSIS package, download <a href="https://zappysys.com/products/ssis-powerpack/download">SSIS PowerPack</a> and review the <a href="https://zappysys.com/api/integration-hub/sharepoint-connector/ssis">SharePoint Online Connector guide</a>.</p>
