Excel Connection Manager can be used to read the single/multiple Excel files. This connection manager supports for password protected workbooks (Not found in native SSIS Excel connection from Microsoft).
In this tutorial we will learn how to Create Excel Connection. You can create multiple connections too based on your requirements.
  1. Before we get started, We need Password credentials of the Excel file if it is password protected.
  2. Download and Install SSIS ZappySys PowerPack.
  4. Right click on Connection Managers Panel to Create New Excel Connection for Excel File, and Context Menu will appear, Select New Connection from the Context Menu.
    SSIS Create New Connection
  5. Select ZS-Excel Connection Manager from the Connection Managers list and Click on Add Button.
  6. In the opened Excel connection manager window, set the "Source Path" with the file name and the appropriate extension. This will be useful for reading from and/or writing to the single Excel file. To read the multiple excel files using Excel Source component, you can use the Pattern approach in the Excel Connection Manager.
    NOTE: The Pattern is only applicable for the Excel Source, you can't use it in Excel Destination component.
    SSIS Excel Source - Connection Configure
    NOTE: If you want to operation with multiple files then use wildcard pattern as below (when you use wildcard pattern in source path then system will treat source path as folder regardless you end with slash).
    Examples:
    c:\SSIS\Excel\file123.xlsx (single file).
    c:\SSIS\Excel\file*.xlsx (all files starting with name file).
    c:\SSIS\Excel\subfolder\*.xlsx (all files with .xlsx Extension and located under folder subfolder).
  7. Click on "Test Connection" to check if the configuration is correct or not.
  8. Click "OK" to save the Excel Connection configuration settings in the UI.
  9. Once you have finished, you will see the Excel connection in the Connection Manager panel.
    Excel Connection Manager - Execute
Path Excel file path
CreateFileIfMissing Automatically create missing excel file
OpenPassword
EditPassword
ConnectionString
SMTP Connection Manager - Setting UI
