SSIS XML Parser Transform
SSIS XML Parser Transform can parse XML string into multiple columns and rows (Helpful to extract data from raw XML string stored as database column or coming from other source).
MaxRows Maximum XML records to fetch. Set this value to 0 for all records
ReplaceWith String you like to replace with (Only valid when EnableCustomReplace option is turned on). If you added --regex or --regex-ic at the end of your SearchFor string then ReplaceWith can use special placeholders (i.e. $1, $2...) based on regular expression groups. For example you SearchFor=(\w+)(@\w+.com) to search for emails then to mask emails you can something like this for ReplaceWith = ****$2 (where $2 is domain part and $1 is before @)
SampleData Sample XML data used to parse output columns.
OutputAllUpstreamColumns Include all upstream parent columns into output except the one you selected to parse. By default only parsed columns from Input document is included in the output. If you wish to include all other upstream columns in the output too then check this option.
EmptyInputProcessingMode Defines how to handle empty input. By default NULL or Empty input is skipped from parsing.
IgnoreEmpty [0] Skip Empty / NULL documents
OutputAsNull [1] Process Empty / NULL documents
ThrowError [2] Throw Error on Empty / NULL documents
UseCustom [3] Use custom value for Empty / NULL documents
TreatEmptyInputAs Defines how to handle empty input. By default NULL or Empty input is skipped from parsing.
ExcludedProperties List comma separated property names from XML document which you want to exclude from output. Specify parent property name to exclude all child nodes.
None [0] Keep date as string
ConvertFormat Output convert raw XML document to JSON (Recommended). This option is ignored if OutputRawDocument=false. Once you do that any further parsing downstream must use JSON Parser rather than XML Parser.
ElementsToTreatAsArray Comma separated element names which you want to treat as Array regardless how many times element repeats at the same level. By default only those elements are treated as array if element appears more than once at the same level.
EnablePerformanceMode Enables memory optimized mode. You may lose certain functionality when you turn on this. Only turn on this feature if you getting out of memory error.
None [0] None
RawOutputDataRowTemplate When you enable EnableRawOutputModeSingleRow you can use this property. Template must be in JSON format (e.g. { data: [$1] } ). [$1] means content extracted using first expression or no expression (i.e. raw data). If RawOutputFilterExpr contains multiple expressions (separated by || ) then you can use multiple placeholders (i.e. [$1], [$2]...[$N]). RawOutputFilterExpr can have JsonPath, XmlPath, RegEx (set RawOutputExtractMode).
Auto [0] Auto
Screenshots
SSIS XML Parser Transform - Parse XMl Document, Convert XML to CSV or save to RDBMS (e.g. SQL Server, MySQL)
Click here to see all articles for [SSIS XML Parser Transform] category
Parse XML string into multiple columns and rows using SSIS
Introduction In our previous blog we saw How to export XML from SQL Server using SSIS. Now in this blog, we will Parse XML string into multiple columns and rows using SSIS XML Parser Transform can (Helpful to extract data from raw XML string stored as database column or coming from other source). Ability to de-normalize nested XML […]
Read / Write Zoho CRM data using SSIS REST API Call
Introduction In this post, you will learn how to read / write Zoho CRM data using SSIS (Drag and drop approach without any coding).  We will use SSIS JSON/ REST API Source to extract data from Zoho API and use SSIS Web API Destination to write data to Zoho. We will look at step-by-step instructions to read Zoho CRM […]
Load SQL Server data to Workday using SSIS / SOAP API
Introduction In our previous article, we saw step-by-step approach to read data from workday using SSIS. In this article, we will focus on how to load SQL Server data to Workday (e.g. POST, Create, Update). We will use SSIS Web API Destination and the combination of other Transforms such as SSIS Template Transform and SSIS XML Generator […]
