System Requirements and Installation
Tip: SSIS PowerPack is a collection of powerful SSIS components for integrating virtually any data source — REST, JSON, XML, CSV, API, OData, Amazon S3, Azure, Google, and more.
Design Prerequisites
To design SSIS packages, install Visual Studio with the SQL Server Integration Services Projects (SSIS Designer) extension.
Supported SSIS Versions
Supported SQL Server Version for SSIS Package Deployment
Supported SQL Server Editions
Azure Data Factory – SSIS Integration Runtime
Operating System Requirements
Installation Steps
  1. Download the SSIS PowerPack Installer:
    https://zappysys.com/downloads/ssis-powerpack
  2. Run the installer and follow the on-screen instructions.
  3. Restart Visual Studio after installation (if open).
  4. Launch Visual Studio and create a new SSIS project to start using SSIS PowerPack.
Important: If you purchased the software, download the installation file from the Customer Download Area. You cannot activate a purchased license key with the public trial build.
Uninstallation
  1. Go to Add or Remove Programs in Windows and search for ZappySys SSIS PowerPack.
  2. Select it and click Uninstall.
  3. If you installed separate builds for different SQL/VS versions, uninstall each version as needed.
Troubleshooting Tips
For Beginners: Refer to this article – Getting started guide (How to design, debug, deploy, and schedule SSIS packages using SQL Agent and SSIS Catalog).
For additional support, visit our Support Portal.
