ZappySys Data Gateway Service provides connectivity to any ZappySys ODBC Drivers or other ODBC Drivers without installing driver on the server where you need to get the data. You can connect to ZappySys Gateway using any standard SQL Server Driver (ODBC, JDBC, OLEDB or ADO.net) and query data sources.
Articles
Click here to see all articles for [ODBC Gateway] category
Get data from Google Search Console API in SSIS and ODBC Apps
Introduction In our previous few posts we saw how to call various google apis in SSIS.  In this post lets learn how to call Google Search Console API in SSIS or other ODBC Compatible Apps such as Power BI, Informatica, SSRS using API Drivers for ODBC About Google Search Console API (Google Webmaster API) If […]
Import Amazon S3 files into SQL Server (CSV/JSON/XML Driver)
Introduction There might be a case when you have many CSV, JSON or XML files in Amazon S3 bucket and you want them to be imported straight into a SQL Server table. Here come ZappySys ODBC PowerPack and ZappySys Data Gateway (part of ODBC PowerPack) which will enable you to accomplish that. ZappySys ODBC PowerPack includes powerful […]
Import Azure Blob files into SQL Server (CSV/JSON/XML Driver)
Introduction There might be a case when you have many CSV, JSON or XML files in Azure Blob and you want them to be imported straight into a SQL Server table. Here come ZappySys ODBC PowerPack and ZappySys Data Gateway (part of ODBC PowerPack) which will enable you to accomplish that. ZappySys ODBC PowerPack includes powerful Azure […]
Import SAP S/4HANA OData Service Data Into Sql Server via ODBC Driver
Introduction In our previous blog we saw how to read JIRA data in SQL Server. Now let’s learn how to Import SAP S/4HANA OData Service Data Into Sql Server. SAP S/4HANA provides OData REST API interface to access data in your application using HTTP Protocol. We will use ODBC XML Driver to read SAP data and load […]
ODBC PowerPack v1.1.3 Released
What’s New In this release we focused on adding URL JOIN Features which may allow many multi steps scenarios in one query. Bing Ads, Amazon MWS, Google BigQuery, Amazon Athena all these supports Job style queries which needs 3 step process (Create job, keep checking status, once done read report data). We also improved compatibility […]
Import Bing Ads data into SQL Server (Performance Reports)
Introduction In our previous blog post we saw how to import REST / SOAP API in SQL Server. Using same concepts let’s look at how to import Bing Ads data into SQL Server. We will explore many techniques to call Bing Ads API and learn how to automate data extraction without doing any ETL. You […]
How to import Amazon MWS data into SQL Server (T-SQL)
Introduction In our previous blog post we saw how to import rest API in SQL Server. Using same concepts lets look at how to import Amazon MWS Data into SQL Server. We will explore many techniques to call Amazon MWS API and learn how to automate Amazon MWS data extraction without doing any ETL. We […]
Import Google Analytics data into SQL Server / Reporting / ETL
Introduction In our previous article we saw how to read Google Analytics data using SSIS. But what if you don’t use SSIS and you still like to Import Google Analytics data into SQL Server or Read inside other Reporting / ETL Apps (e.g. Excel, Power BI, MS Access … and many more). Not all BI […]
Read / Write REST API data in Talend (JSON / XML / SOAP)
Introduction In this post we will learn how to read / write REST API data in Talend Open Studio. We will create a simple Talend Job using ZappySys JSON  Driver to read from REST API / JSON Files and load into Target (e.g. File / DB). Techniques listed in this article can be also used to read […]
Insert, Update and Delete JIRA Issue in SQL Server
Introduction In our previous blog we saw how to read JIRA data in SQL Server. In this blog, we will learn how to Insert, Update and Delete Issue in JIRA using ZappySys JSON Driver. We will also read data from SQL Server data table in stored-procedure and insert JIRA issues in bulk, along with few other […]
