Driver={ZappySys Csv Driver}[,Attribute1=Value;][,Attribute2=Value;]........[,Attribute3=Value;]
Syntax: (Using DSN)
DSN=YourDsnName;[,Attribute1=Value;][,Attribute2=Value;]........[,Attribute3=Value;]
| Attribute | Label | Description | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| AccessMode (Setting of CsvConfigurationParams) | AccessMode | Defines how to read data from file path/URL or direct string
| ConnectionStringFile (Setting of CsvConfigurationParams) | ConnectionStringFile | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Data (Setting of CsvConfigurationParams) | DirectValue | Direct String you like to use as a datasource. This attribute always takes precedence if both Data and Src defined (i.e. File/Url). You can also use AccessMode=1 along with Data='...' in WITH clause to use Direct String rather than URL/File. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| EnableCustomReplace (Setting of CsvConfigurationParams) | EnableCustomReplace | Enables custom search / replace in the document text after its read from the file/url or direct string. This replace operation happens before its parsed. This option can be useful for custom escape sequence in source document which is causing issue in the parser. You can replace such unwanted characters fore parser starts parsing the text. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| IgnoreContentLengthHeaderForGzipResponse (Setting of CsvConfigurationParams) | IgnoreContentLengthHeaderForGzipResponse | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Pwd (Setting of CsvConfigurationParams) | Pwd | Maps to ODBC 'Password'. Default: Basic auth Password. For OAuth/modern auth without Password, map Uid into another field (e.g. ClientSecret) by setting that field's value to {$pwd$}. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ReplaceWith (Setting of CsvConfigurationParams) | ReplaceWith | String you like to replace with (Only valid when EnableCustomReplace option is turned on). If you added --regex or --regex-ic at the end of your SearchFor string then ReplaceWith can use numbered group placeholders (e.g. $1, $2...) or use group name as placeholder (e.g. ${username}, ${domain}) any where in the replacement string. For example to search and replace emails and remove just user name from it you can do below SearchFor=(?<username>\w+)(?<domain>@\w+.com) ReplaceWith = ****$2 -OR- ReplaceWith = ****${domain} | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| SearchFor (Setting of CsvConfigurationParams) | SearchFor | String you like to search for (Only valid when EnableCustomReplace option is turned on). If you want to enable Regular Expression pattern search then add --regex or --regex-ic (for case-insensitive search) at the end of your search string (e.g. ORDER-\d+--regex OR ORDER-\d+--regex-ic (case-insensitive search) ) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Uid (Setting of CsvConfigurationParams) | Uid | Maps to ODBC 'User Name'. Default: Basic auth UserName. For OAuth/modern auth without UserName, map Uid into another field (e.g. ClientId) by setting that field's value to {$uid$}. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Cache Settings | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| CacheEntryTtl (Setting of CsvConfigurationParams) | Cache entry lifetime, sec | This property indicates how many seconds data is kept in cache (in case caching is enabled) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| CacheFileLocation (Setting of CsvConfigurationParams) | Cache file location | This property allows you to set cache file location (you have to set Cache persistence mode to Storage) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| CacheStorage (Setting of CsvConfigurationParams) | Cache storage | Specifies cache storage - in-memory only or local data file
| CachingMode (Setting of CsvConfigurationParams) | Cache mode | Enables or disables cache usage for metadata / data
| CSV Settings | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| AllowComment (Setting of CsvConfigurationParams) | AllowComment | Allow comment lines which can be skipped by parser. When comment line found row is skipped. See CommentCharacter to configure first character for commented line. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ColumnDelimiter (Setting of CsvConfigurationParams) | ColumnDelimiter | Column delimiter for data you like to parse. To use custom delimiter enter 4-digit hex string starting with \x (e.g. you can enter \x0009 for Tab character). For multiple characters repeat group. e.g. \x00090009 if you need two tabs. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| CommentCharacter (Setting of CsvConfigurationParams) | CommentCharacter | Allow lines with comment. When comment line found row is skipped. See LineCommentCharacter property to configure first character for commented line. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| HasColumnHeaderRow (Setting of CsvConfigurationParams) | HasColumnHeaderRow | Column delimiter for data you like to parse. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| IgnoreBlankLines (Setting of CsvConfigurationParams) | IgnoreBlankLines | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| IgnoreQuotes (Setting of CsvConfigurationParams) | IgnoreQuotes | Ignore quote character and consider it part of actual value | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| QuoteCharacter (Setting of CsvConfigurationParams) | QuoteCharacter | Quote character for quoted values. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| SkipEmptyRecords (Setting of CsvConfigurationParams) | SkipEmptyRecords | When this option is enabled, any row with empty values in all fields is skipped (e.g. , , , , ). | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| SkipHeaderCommentRows (Setting of CsvConfigurationParams) | SkipHeaderCommentRows | Total rows you like to skip before header row. If its header less file then skip initial N rows (before any data row). | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| SkipRows (Setting of CsvConfigurationParams) | SkipRows | Total data rows you like to skip (after header row) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ThrowErrorOnColumnCountMismatch (Setting of CsvConfigurationParams) | ThrowErrorOnColumnCountMismatch | Throw error if record has different number of columns than actual columns detected based on first row | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ThrowErrorOnNoRecordFound (Setting of CsvConfigurationParams) | ThrowErrorOnNoRecordFound | Throw error if no record found or file is blank | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| TreatBlankAsNull (Setting of CsvConfigurationParams) | TreatBlankAsNull | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| TrimFields (Setting of CsvConfigurationParams) | TrimFields | Trim value for each field if whitespace found before or after | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| TrimHeaders (Setting of CsvConfigurationParams) | TrimHeaders | Trim column names if whitespace found before or after name | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Encoding / Culture Settings | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| CharacterSet (Setting of CsvConfigurationParams) | CharacterSet | Character set for text (e.g. utf-8 ) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Culture (Setting of CsvConfigurationParams) | Culture | Culture code (e.g. pt-BT). This helps to parse culture specific number formats (e.g. In some culture you may have comma rather than decimal points 0.1 can be 0,1) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Encoding (Setting of CsvConfigurationParams) | Encoding | Encoding of source file
| Error Handling Settings | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ConsumeResponseOnError (Setting of CsvConfigurationParams) | Consume response on error | When error occurs no data is returned. Use this option to get content eventhough error occurs. When this option is checked you can't use [continue on error when specific string found in response] option | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ContineOn404Error (Setting of CsvConfigurationParams) | Continue on error #404 | Set this parameter to True if you want to continue execution if HTTP error #404 is returned by API | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ContineOnAnyError (Setting of CsvConfigurationParams) | Continue on any error | If this parameter is set to True then any HTTP error returned by API will be ignored | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ContineOnErrorForMessage (Setting of CsvConfigurationParams) | Continue on message | If value of this parameter is found in API status response text - query processing will be continued | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ContineOnErrorForStatusCode (Setting of CsvConfigurationParams) | Continue on status code | Query processing will be continued in case HTTP status code of response is equal to the value of this parameter | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ConvErrorHandlingMode (Setting of CsvConfigurationParams) | Error handling for data conversion | Determines whether data conversion errors are ignored or interrupt execution.
| ErrorStatusCodeToMatch (Setting of CsvConfigurationParams) | Error on status code | HTTP status code of API response will trigger error in case it matches the value of this parameter | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ErrorSubstringToMatch (Setting of CsvConfigurationParams) | Error on message | If API status response contains the value of this parameter - execution will be terminated by error | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| MatchForEqual (Setting of CsvConfigurationParams) | Match StatusCode for Equal | If true then error statuscode is checked for equal condition else checked for not equal condition. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| TruncationHandlingMode (Setting of CsvConfigurationParams) | Error handling for data truncation | Determines whether data truncation errors are ignored or interrupt execution. This setting is only used when custom META is supplied or ConvErrorHandlingMode is set to Ignore errors.
| Value (Setting of NameValuePair) | Value | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| HTTP Settings-1 (General) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| IsMultiPart (Setting of CsvConfigurationParams) | Is File Upload Request | Check this option if you want to upload file(s) (i.e. POST RAW file data) or send data using Multi-Part encoding method (i.e. Content-Type: multipart/form-data). Multi-Part request allows you to mix key/value and upload files in same request. On the other hand raw upload allows only single file upload (without any key/value) ==== Raw Upload (Content-Type: application/octet-stream) ===== To upload single file in raw mode check this option and specify full file path starting with @ sign in the Body (e.g. @c:\data\myfile.zip ) ==== Form-Data / Multipart Upload (Content-Type: multipart/form-data) ===== To treat your Request data as multi part fields you must specify key/value pairs separated by new lines into RequestData field (i.e. Body). Each key value pair is entered on new-line and key/value are separated using equal sign (=). Preceding and trailing spaces are ignored also blank lines are ignored. If field value has some any special character(s) then use escape sequence (e.g. For NewLine: \r\n, For Tab: \t, For at (@): \@). When value of any field starts with at sign (@) its automatically treated as File you want to upload. File content type is determined based on extension. See below Example of uploading multiple files along with additional fields. file1=@c:\data\Myfile1.txt file2=@c:\data\Myfile2.txt SomeField1=aaaaaaa SomeField2=12345 SomeFieldWithNewLineAndTab=This is line1\r\nThis is line2\r\nThis is \ttab \ttab \ttab SomeFieldStartingWithAtSign=\@MyTwitterId | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RequestContentTypeCode (Setting of CsvConfigurationParams) | Request ContentType | Specifies content type for data you wish to POST. If you select Default option then system default content type will be used (i.e. application/x-www-form-urlencoded). If you specify Content-Type header along with this option then header value takes precedence.
| RequestData (Setting of CsvConfigurationParams) | Request data (Body) | User defined data that will be sent in HTTP Request (e.g. Upload file data, Form POST data etc). In case Request method is set to 'POST' system will automatically set content-type header to 'application/x-www-form-urlencoded' unless you selected different Request Content Type. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RequestMethod (Setting of CsvConfigurationParams) | Request Method | Http Web Request Method (e.g. POST, GET, PUT, LIST, DELETE...). Refer your API documentation if you are not sure which method you have to use. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RequestTimeoutMs (Setting of CsvConfigurationParams) | Request timeout (milliseconds) | Http request Timeout in milliseconds (1000 ms = 1 second). This setting determines how long you want to wait before throwing error if server doesn't respond in specified timeout. Set this to 0 if you want to use system default value (i.e. 100 seconds) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| SupportCompression (Setting of CsvConfigurationParams) | Support compression | Enable this to support HTTP compression | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| UserAgent (Setting of CsvConfigurationParams) | User agent | Value of this parameter will be sent in HTTP User-Agent header | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| HTTP Settings-2 (Advanced) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| EnableBodyPlaceholderForMultiPart (Setting of CsvConfigurationParams) | EnableBodyPlaceholderForMultiPart | By default placeholders (e.g. <%access_token%> or [$a.MyColumn$]) are not replaced when you Enable MultiPart File Upload option to speedup performance. However in some case if you like to use placeholder inside file content you trying to use as Body then enable this option. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| IgnoreSSLCertificateErrors (Setting of CsvConfigurationParams) | Ignore SSL certificate errors | Set this parameter to True if SSL certificate errors must be ignored | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| PreventAutoRedirect (Setting of CsvConfigurationParams) | Prevent Auto Redirect (301, 302 redirect) | By default HTTP 301 and 302 redirects are allowed. For some reason you want to disable it then set this option. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| StreamReadWriteTimeoutMs (Setting of CsvConfigurationParams) | Read/write timeout, ms | Defines timeout for API requests and responses. 0 means no time limits | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| UseSslVersion (Setting of CsvConfigurationParams) | SSL/TLS version | SSL/TLS Version for HTTPS requests
| Log Settings | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| LoggingLevel (Setting of CsvConfigurationParams) | Log level | Sets level of messages logged
| LogPath (Setting of CsvConfigurationParams) | Log file location | Sets location for the log file (empty value means no log written) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| LogRollingMode (Setting of CsvConfigurationParams) | Log rolling mode | Sets log file rolling mode. Log file may be restricted by log file size or by number of latest log files (one log file per day).
| LogSize (Setting of CsvConfigurationParams) | Maximum log file size (Mb) | Sets limit for log file size (0 means no limit, old log entries will be discarded if size limit is reached) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| MaxLogFiles (Setting of CsvConfigurationParams) | Number of log files to keep (0 - keep all, actual for LogRollingMode=Days) | Set a number to keep N latest log files. Actual for LogRollingMode=Days. Set 0 to keep all files. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Reference (Setting of ColumnDescriptor) | Reference | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| GroupName (Setting of ColumnsMetadata) | Group name | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| OverrideMode (Setting of ColumnsMetadata) | OverrideMode | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Metadata Settings | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| MetaScanMode (Setting of CsvConfigurationParams) | Metadata Scan Mode / Multiplier | Metadata guess mode / multiplier to detect length by scanning rows defined in
| MetaTreatStringAsAscii (Setting of CsvConfigurationParams) | Treat string as ASCII | When this option is true, it detects all string values as DT_STR (Ascii) rather than DT_WSTR (Unicode) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RowsToScanForMetadata (Setting of CsvConfigurationParams) | Number of rows scanned to collect metadata | If metadata isn't defined for query the driver will try to scan some rows to guess fields parameters | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| TreatBlankBoolAsNull (Setting of CsvConfigurationParams) | Treat blank BOOLEAN value as NULL | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| TreatBlankDateAsNull (Setting of CsvConfigurationParams) | Treat blank DATE/TIME value as NULL | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| TreatBlankNumberAsNull (Setting of CsvConfigurationParams) | Treat blank NUMERIC value as NULL | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Other Settings | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| DateParseHandling (Setting of CsvConfigurationParams) | Date data type | Specifies how dates are parsed.
| EnableBigNumberHandling (Setting of CsvConfigurationParams) | Enable Big Number Handling | When this option is checked, sytem allows to parse large number (Higher than Int64) in JSON document (i.e. { id: 76000009353950433247780 } ). If you do not turn on this option then it may throw error if large number is encountered. This option is SLOW becuase it has to perform additional checks in order to avoid Large number overflow error so do not turn on unless you getting Large number error. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| FloatParseHandling (Setting of CsvConfigurationParams) | FloatParseHandling | Specifies how decimal values are parsed when reading JSON. Change this setting to Decimal if you like to have large precision / scale.
| Recursive (Setting of CsvConfigurationParams) | Scan files recursively | Scan files recursively when you read from local files (i.e. include files from sub folders). | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RegexReplaceListForSql (Setting of CsvConfigurationParams) | List of regular expressions for SQL modification | Regular expressions and replacement patterns are applied to SQL request executed by the driver, for instance: (?<column>\w+)=True||(?<column>\w+)=False|~|${column}=1||${column}=0 will replace all instances of SomeColumn=True with SomeColumn=1 and all instances of SomeColumn=False with SomeColumn=0 in all SQL requests. You can use regex group name as ${some-group-name} (only if defined as (?<some-group-name>..) anywhere in the regex) or use regex group number in the replacement string (e.g. $1, $2..). Regex pattern match is case-insensitive. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Output Settings | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| DateFormatString (Setting of CsvConfigurationParams) | Date format | Specifies date format | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| DefaultRowLimit (Setting of CsvConfigurationParams) | Default data row limit (i.e. LIMIT / TOP clause) | Use this option if you like to limit number of rows fetched by any query. If you use LIMIT clause in the query then this option is ignored. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| EnableArrayFlattening (Setting of CsvConfigurationParams) | Enable Array Flattening | Enables deep array flattening for selected filtered hierarchy. When you turn on this property it will flatten each property of each array item and expose as column (e.g. If you have Filter set as $.customers[*] and for each customer you have an array of Addresses then you may see output columns like Addresses.1.City, Addresses.1.State, Addresses.2.City, Addresses.2.State .... Addresses.N.City, Addresses.N.State). You can control how many array items you want to flatten by setting MaxArrayItemsToFlatten property. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| EnablePivot (Setting of CsvConfigurationParams) | Enable Pivot | When this property is true then Column is converted to Row. Pivoted names will appear under Pivot_Name column and values will appear under Pivot_Value field. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| EnableRawOutputModeSingleRow (Setting of CsvConfigurationParams) | Enable Raw Document - Single Row (Disable parser, allow any format) | Enable Raw Document Output Mode for any format (i.e. XML, Html, Text, Json). Unlike other option EnableRawOutputMode, this option doesn't invoke parser to extract documents by finding row terminator. It will source string as row value in single row/ single column. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| FileCompressionType (Setting of CsvConfigurationParams) | FileCompressionType | Compression format for source file (e.g. gzip, zip)
| MaxArrayItemsToFlatten (Setting of CsvConfigurationParams) | Max Array Items To Flatten | Maximum number of array items to flatten. inner array flattening. Adjust this property to control how many columns being generated. This option is ignored if you set EnableArrayFlattening=false | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RawOutputDataRowTemplate (Setting of CsvConfigurationParams) | RawOutputDataRowTemplate | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RawOutputExtractMode (Setting of CsvConfigurationParams) | RawOutputExtractMode |
| RawOutputFilterExpr (Setting of CsvConfigurationParams) | RawOutputFilterExpr | Use this property to define one or multiple expressions (i.e. JsonPath,XPath,Regex) to extract information from source. This property is only valid when EnableRawOutputModeSingleRow=true and RawOutputDataRowTemplate is set. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| SaveContentAsBinary (Setting of CsvConfigurationParams) | SaveContentAsBinary | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Pagination Settings | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| EnablePageTokenForBody (Setting of CsvConfigurationParams) | EnablePageTokenForBody | If you wish to pass extracted pagination token in the body of next request then set this option to true. You can use [$pagetoken$] placeholder anywhere in the Body where you wish to insert extracted Page token. You must set encoded token you can use <%nextlink_encoded%> inside SuffixForNextUrl Property. If you dont use SuffixForNextUrl then raw nextLink or Token will be inserted inside the body. If you dont specify [$pagetoken$] placeholder in the body then NextPage Token will be appended at the end. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| FirstPageBodyPart (Setting of CsvConfigurationParams) | FirstPageBodyPart | Use this property to set request body fragment for first page. HasDifferentNextPageInfo must be set to true to use this property. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| HasDifferentNextPageInfo (Setting of CsvConfigurationParams) | HasDifferentNextPageInfo | Set this to true if you wish to specify different URL, Header, Body or Filter for first page and next page (i.e. Paginated response). Some APIs like Amazon MWS, NetSuite, Zuora) you may need to set this to true. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| IncrementBy (Setting of CsvConfigurationParams) | Page number increment | Page counter increment. By default next page is incremented by one if this value is zero. You can also enter negative number if you want to decrease page counter. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| NextPageBodyPart (Setting of CsvConfigurationParams) | NextPageBodyPart | Use this property to set request body fragment for any request after first request. HasDifferentNextPageInfo must be set to true to use this property. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| NextUrlAttributeOrExpr (Setting of CsvConfigurationParams) | Next Url AttributeName or Expression | Specifies attribute name or expression (e.g. $.pageInfo.nextUrl ) that contains next page Url (for the case data contains next Url attribute). If no attribute with such name is found or its value is null then data fetch is completed | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| NextUrlEndIndicator (Setting of CsvConfigurationParams) | Next Url Stop Indicator Value | Specifies value which indicates last page to stop pagination. If you have specified StopIndicatorAttribute then you can use Regular expression rather than static value to indicate last page. To use regular expression value of this property must start with regex= prefix. Example : regex=FALSE|N (assuming you set StopIndicatorAttribute to something like $.hasMore) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| NextUrlSuffix (Setting of CsvConfigurationParams) | Next Url suffix | If you want to include certain text (or parameters) at the end of Next url then specify this attribute (e.g. &format=json) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| PagePlaceholders (Setting of CsvConfigurationParams) | PagePlaceholders | When HasDifferentNextPageInfo=true you can set this property to indicate first page and next page. You can specify different URL, Header, Body or Filter for first page and next page (i.e. Paginated response). Use [$tag$] as placeholder anywhere in the URL, Header, Body or Filter and at runtime system will replace it with correct value (first page or next page value). Syntax to specify placeholder for first page vs next page is like a connectionstring url=FirstPageValue|NextPageValue;header=FirstPageValue|NextPageValue;body=FirstPageValue|NextPageValue;filter=FirstPageValue|NextPageValue; You can use one or more key/value pairs to make things dynamic (e.g. url, header, body or filter) .For example if you have pagination in your API and First URL is http://abc.com/api/items/get and to get more records you have to call http://abc.com/api/items/getNext then you can use [$tag$] as placeholder in the URL http://abc.com/api/items/[$tag$] and specify this property with first page tag and next page tag as url=get|getNext (Tags are separated using vertical bar). | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| PagingByUrlAttributeName (Setting of CsvConfigurationParams) | Page number Url parameter name | e.g. Type page_num if URL looks like this => http://abc.com/?page_num=1&sort=true (page number via query string) --or-- Type <%page%> if page number is inside URL path like this => http://abc.com/1/?sort=true (e.g. replace page number in url with placeholder http://abc.com/<%page%>/?sort=true) Page number will be incremented by one for next URL until last page is reached or [Max Page Number] is reached. This parameter also controls pagination mode [ByResponseHeaderContinuationToken]. When this mode is used you can enter RESPONSE_HEADER_NAME --OR-- NEXT_QUERY_PARAM=RESPONSE_HEADER_NAME --OR-- NEXT_QUERY_PARAM=RESPONSE_HEADER_NAME(regular_expression). If NEXT_QUERY_PARAM (left side) is omitted then Response Header value is sent to next request in the same Header name. If you like to pass response header value in the next URL then use two parts (e.g. cursor=X-CONTINUE-TOKEN) ... this example will read X-CONTINUE-TOKEN header from response and pass it to next request in the URL like http://myapi.com/?cursor=[value-from-previous-response]. You can also use advanced syntax using Regular expression to extract substring from response header value (e.g. cursor=X-CONTINUE-TOKEN(\d*)) will extract only numeric part from header value. Another example is cursor=X-CONTINUE-TOKEN(^((?!null\b).)*$) ... this will return value if its other than "null" (word). For more information about using regular expression check this link https://zappysys.com/links/?id=10124 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| PagingByUrlCheckResponseErrString (Setting of CsvConfigurationParams) | Error string | Response is treated as invalid if it contains specified error string. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| PagingByUrlCheckResponseMaxBytes (Setting of CsvConfigurationParams) | Maximum response length | Maximum length of valid response (bytes). | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| PagingByUrlCheckResponseMinBytes (Setting of CsvConfigurationParams) | Minimum response length | Minimum length of valid response (bytes). | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| PagingByUrlCheckResponseStatusCode (Setting of CsvConfigurationParams) | 'Not found' status code | Expected HTTP status code to stop pagination (This is only used if [Last page trigger] is set based on HTTP StatusCode). | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| PagingByUrlCurrentPage (Setting of CsvConfigurationParams) | Starting Page Number | Specifies starting page number. This will be incremented each time when next request is made until last page is reached. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| PagingByUrlEndStrategy (Setting of CsvConfigurationParams) | Last page trigger | Specifies the way last page is detected.
| PagingByUrlLastPageWhenConditionEqualsTo (Setting of CsvConfigurationParams) | Use condition to detect last page | Enables or disables usage of condition to detect last page. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| PagingByUrlMaxPages (Setting of CsvConfigurationParams) | Maximum page number | Maximum page number until which auto increment is allowed. Type zero for no limit. Next URL contains next page number (increment by one) until last page is detected or [Max Page Number] limit is reached. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| PagingMaxPagesExpr (Setting of CsvConfigurationParams) | PagingMaxPagesExpr | Expression to extract Maximum pages to loop through. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| PagingMaxRowsDataPathExpr (Setting of CsvConfigurationParams) | PagingMaxRowsDataPathExpr | When you enable PagingMaxRowsExpr (end pagination based on MaxRowCount) then you need to count records coming in each response. This expression extract all rows found under specified expression (e.g. $.orders[*] if all records found under orders node). | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| PagingMaxRowsExpr (Setting of CsvConfigurationParams) | PagingMaxRowsExpr | Expression to extract Maximum records to loop through. Some APIs don't stop pagination and keep returning last page data when you try to read data after last page. Specify expression (e.g. $.total_rows ) to read total pages to loop through using this property. This setting is ignored if you set PagingMaxPagesExpr. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| PagingMode (Setting of CsvConfigurationParams) | Paging mode | Specifies the mode of fetching multiple pages of data returned by REST API.
| StopIndicatorAttributeOrExpr (Setting of CsvConfigurationParams) | Stop Indicator AttributeName or Expression | Name of attribute or expression for attribute which can be used as stop indicator (e.g. hasmore --or-- $.pagination.hasmore). If this value is blank then 'Next Url attribute' is used | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| WaitTimeMs (Setting of CsvConfigurationParams) | Request throttle time | This option indicates number of milliseconds to wait after each request so it is possible to adjust how many API calls can be made within certain timeframe. If used API Service has no API call limit then this option should be set to 0 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Query Engine Temp Storage | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| TempStorageMode (Setting of CsvConfigurationParams) | Intermediate results storage | Use [Disk] if number of resulting rows or row data size is large
| CertificatePassword (Setting of ClientCertificateInfo) | CertificatePassword | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| CertificatePath (Setting of ClientCertificateInfo) | CertificatePath | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| DisplayPath (Setting of ClientCertificateInfo) | DisplayPath | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| EnableCertificate (Setting of ClientCertificateInfo) | EnableCertificate | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| IgnoreValidationErrors (Setting of ClientCertificateInfo) | IgnoreValidationErrors | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| IsServiceAccount (Setting of ClientCertificateInfo) | IsServiceAccount | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| StorageType (Setting of ClientCertificateInfo) | StorageType |
| StoreName (Setting of ClientCertificateInfo) | StoreName |
| Thumbprint (Setting of ClientCertificateInfo) | Thumbprint | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| LogLevel (Setting of ILogger) | LogLevel |
| PrefixTimestamp (Setting of ILogger) | PrefixTimestamp | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| DoNotUseDefaultProxy (Setting of ProxyInfo) | DoNotUseDefaultProxy | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| EnableProxy (Setting of ProxyInfo) | EnableProxy | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ProxyAuthMode (Setting of ProxyInfo) | ProxyAuthMode |
| ProxyDomain (Setting of ProxyInfo) | ProxyDomain | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ProxyHost (Setting of ProxyInfo) | ProxyHost | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ProxyPassword (Setting of ProxyInfo) | ProxyPassword | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ProxyPort (Setting of ProxyInfo) | ProxyPort | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ProxyType (Setting of ProxyInfo) | ProxyType |
| ProxyUrl (Setting of ProxyInfo) | ProxyUrl | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ProxyUseCreds (Setting of ProxyInfo) | ProxyUseCreds | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ProxyUser (Setting of ProxyInfo) | ProxyUser | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| MaxRetryCount (Setting of RetryInfo) | MaxRetryCount | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| MessageListToHandle (Setting of RetryInfo) | MessageListToHandle | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| MultiplyWaitTimeForEachAttempt (Setting of RetryInfo) | MultiplyWaitTimeForEachAttempt | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RetryMode (Setting of RetryInfo) | RetryMode |
| StatusCodeListToHandle (Setting of RetryInfo) | StatusCodeListToHandle | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| WaitTimeMs (Setting of RetryInfo) | WaitTimeMs | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| AuthScheme (Setting of HttpConnection) | AuthScheme | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ConnectionString (Setting of HttpConnection) | ConnectionString | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ConnectionStringFile (Setting of HttpConnection) | ConnectionStringFile | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ConnectionStringFull (Setting of HttpConnection) | ConnectionStringFull | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ConnectionStringNonDefaultsOnly (Setting of HttpConnection) | ConnectionStringNonDefaultsOnly | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ConnectionStringNonDefaultsOnlyFull (Setting of HttpConnection) | ConnectionStringNonDefaultsOnlyFull | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| CredentialType (Setting of HttpConnection) | CredentialType |
| DisableCustomUrl (Setting of HttpConnection) | DisableCustomUrl | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| DisableSockProxySupport (Setting of HttpConnection) | DisableSockProxySupport | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| DisableTest (Setting of HttpConnection) | DisableTest | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| DisableThirdPartWebRequest (Setting of HttpConnection) | DisableThirdPartWebRequest | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| EnableRequestHashing (Setting of HttpConnection) | EnableRequestHashing | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ExtraHeaders (Setting of HttpConnection) | ExtraHeaders | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ExtraHeadersForLogin (Setting of HttpConnection) | ExtraHeadersForLogin | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| HashAlgorithm (Setting of HttpConnection) | HashAlgorithm | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| HashDoNotSign (Setting of HttpConnection) | HashDoNotSign | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| HashFormatForBody (Setting of HttpConnection) | HashFormatForBody | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| HashNounce (Setting of HttpConnection) | HashNounce | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| HashSignatureFormat (Setting of HttpConnection) | HashSignatureFormat | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| HashSignatureFormatForLogin (Setting of HttpConnection) | HashSignatureFormatForLogin | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| HashSignWithApiKey (Setting of HttpConnection) | HashSignWithApiKey | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| HashTimestamp (Setting of HttpConnection) | HashTimestamp | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| HashTimestampFormat (Setting of HttpConnection) | HashTimestampFormat | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| HashTreatSecretAsNonBase64 (Setting of HttpConnection) | HashTreatSecretAsNonBase64 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| JwtCustomClaims (Setting of HttpConnection) | JwtCustomClaims | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| MetaBody (Setting of HttpConnection) | MetaBody | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| MetaContentType (Setting of HttpConnection) | MetaContentType |
| MetaFields (Setting of HttpConnection) | MetaFields | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| MetaFilters (Setting of HttpConnection) | MetaFilters | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| MetaHeaders (Setting of HttpConnection) | MetaHeaders | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| MetaMethod (Setting of HttpConnection) | MetaMethod | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| MetaTemplate (Setting of HttpConnection) | MetaTemplate | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| MetaUrl (Setting of HttpConnection) | MetaUrl | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Password (Setting of HttpConnection) | Password | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| PreferProxyUrl (Setting of HttpConnection) | PreferProxyUrl | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RetainCookies (Setting of HttpConnection) | RetainCookies | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RetainSameConnection (Setting of HttpConnection) | RetainSameConnection | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RetryCountMax (Setting of HttpConnection) | RetryCountMax | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RetryMessageList (Setting of HttpConnection) | RetryMessageList | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RetryMode (Setting of HttpConnection) | RetryMode |
| RetryMultiplyWaitTime (Setting of HttpConnection) | RetryMultiplyWaitTime | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RetryStatusCodeList (Setting of HttpConnection) | RetryStatusCodeList | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RetryWaitTimeMs (Setting of HttpConnection) | RetryWaitTimeMs | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| SoapWssPasswordType (Setting of HttpConnection) | SoapWssPasswordType |
| SslVersion (Setting of HttpConnection) | SslVersion |
| StreamReadWriteTimeoutMs (Setting of HttpConnection) | StreamReadWriteTimeoutMs | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| SupportDualProxyMode (Setting of HttpConnection) | SupportDualProxyMode | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Timeout (Setting of HttpConnection) | Timeout | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| TokenAuthHeader (Setting of HttpConnection) | TokenAuthHeader | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| TokenExpirationTimeInSeconds (Setting of HttpConnection) | TokenExpirationTimeInSeconds | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| TokenFunction (Setting of HttpConnection) | TokenFunction | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| TokenRequestContentType (Setting of HttpConnection) | TokenRequestContentType |
| TokenRequestData (Setting of HttpConnection) | TokenRequestData | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| TokenRequestHeaders (Setting of HttpConnection) | TokenRequestHeaders | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| TokenRequestIsMultiPart (Setting of HttpConnection) | TokenRequestIsMultiPart | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| TokenRequestMethod (Setting of HttpConnection) | TokenRequestMethod | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| TokenResponseContentFilter (Setting of HttpConnection) | TokenResponseContentFilter | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| TokenResponseContentType (Setting of HttpConnection) | TokenResponseContentType |
| TokenResponseCookie (Setting of HttpConnection) | TokenResponseCookie | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| TokenResponseHeader (Setting of HttpConnection) | TokenResponseHeader | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| TokenResponseValueExtractMode (Setting of HttpConnection) | TokenResponseValueExtractMode |
| TokenUrl (Setting of HttpConnection) | TokenUrl | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Url (Setting of HttpConnection) | Url | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| UserName (Setting of HttpConnection) | UserName | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| UseThirdPartyWebRequest (Setting of HttpConnection) | UseThirdPartyWebRequest | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| UseWebProxy (Setting of HttpConnection) | UseWebProxy | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| AccessToken (Setting of OAuthConnection) | AccessToken | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| AccessTokenAttrName (Setting of OAuthConnection) | AccessTokenAttrName | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| AccessTokenParamName (Setting of OAuthConnection) | AccessTokenParamName | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| AccessTokenSecret (Setting of OAuthConnection) | AccessTokenSecret | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ApiCategory (Setting of OAuthConnection) | ApiCategory | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| AppendAccessTokenToUrl (Setting of OAuthConnection) | AppendAccessTokenToUrl | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| AppVer (Setting of OAuthConnection) | AppVer | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| AuthorizeInFullBrowser (Setting of OAuthConnection) | AuthorizeInFullBrowser | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| AuthScheme (Setting of OAuthConnection) | AuthScheme | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| AuthUrl (Setting of OAuthConnection) | AuthUrl | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| CacheToken (Setting of OAuthConnection) | CacheToken | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ClientId (Setting of OAuthConnection) | ClientId | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ClientSecret (Setting of OAuthConnection) | ClientSecret | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ConnectionString (Setting of OAuthConnection) | ConnectionString | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ConnectionStringFile (Setting of OAuthConnection) | ConnectionStringFile | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ConnectionStringFull (Setting of OAuthConnection) | ConnectionStringFull | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ConnectionStringNonDefaultsOnly (Setting of OAuthConnection) | ConnectionStringNonDefaultsOnly | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ConnectionStringNonDefaultsOnlyFull (Setting of OAuthConnection) | ConnectionStringNonDefaultsOnlyFull | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ContentType (Setting of OAuthConnection) | ContentType | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| CustomAuthHeader (Setting of OAuthConnection) | CustomAuthHeader | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| CustomTokenPrefix (Setting of OAuthConnection) | CustomTokenPrefix | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| CustomWarningForFullMode (Setting of OAuthConnection) | CustomWarningForFullMode | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| DefaultClientId (Setting of OAuthConnection) | DefaultClientId | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| DefaultClientSecret (Setting of OAuthConnection) | DefaultClientSecret | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| DisableCustomUrl (Setting of OAuthConnection) | DisableCustomUrl | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| DisableSockProxySupport (Setting of OAuthConnection) | DisableSockProxySupport | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| DisableTest (Setting of OAuthConnection) | DisableTest | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| DisableThirdPartWebRequest (Setting of OAuthConnection) | DisableThirdPartWebRequest | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| DoNotIncludeCredentialsInBody (Setting of OAuthConnection) | DoNotIncludeCredentialsInBody | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| DoNotIncludeCredentialsInHeader (Setting of OAuthConnection) | DoNotIncludeCredentialsInHeader | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| DoNotIncludeEmptyParamsInSignature (Setting of OAuthConnection) | DoNotIncludeEmptyParamsInSignature | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| DoNotIncludeTokenInUrl (Setting of OAuthConnection) | DoNotIncludeTokenInUrl | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| EnableCodeVerifier (Setting of OAuthConnection) | EnableCodeVerifier | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| EnableOAuthOverUrl (Setting of OAuthConnection) | EnableOAuthOverUrl | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ExpiresAfterSec (Setting of OAuthConnection) | ExpiresAfterSec | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ExpiresInAttribute (Setting of OAuthConnection) | ExpiresInAttribute | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ExtraAttributesForAuthRequest (Setting of OAuthConnection) | ExtraAttributesForAuthRequest | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ExtraAttributesForTokenRequest (Setting of OAuthConnection) | ExtraAttributesForTokenRequest | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ExtraHeaders (Setting of OAuthConnection) | ExtraHeaders | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| GrantType (Setting of OAuthConnection) | GrantType |
| HasChangingRefreshTokenSupport (Setting of OAuthConnection) | HasChangingRefreshTokenSupport | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| JwtSignMode (Setting of OAuthConnection) | JwtSignMode |
| MetaBody (Setting of OAuthConnection) | MetaBody | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| MetaContentType (Setting of OAuthConnection) | MetaContentType |
| MetaFields (Setting of OAuthConnection) | MetaFields | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| MetaFilters (Setting of OAuthConnection) | MetaFilters | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| MetaHeaders (Setting of OAuthConnection) | MetaHeaders | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| MetaMethod (Setting of OAuthConnection) | MetaMethod | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| MetaTemplate (Setting of OAuthConnection) | MetaTemplate | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| MetaUrl (Setting of OAuthConnection) | MetaUrl | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| NounceForTesting (Setting of OAuthConnection) | NounceForTesting | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| OAuthVersion (Setting of OAuthConnection) | OAuthVersion |
| Password (Setting of OAuthConnection) | Password | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| PreferProxyUrl (Setting of OAuthConnection) | PreferProxyUrl | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Prop1Name (Setting of OAuthConnection) | Prop1Name | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Prop1Value (Setting of OAuthConnection) | Prop1Value | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Prop2Name (Setting of OAuthConnection) | Prop2Name | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Prop2Value (Setting of OAuthConnection) | Prop2Value | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RefreshToken (Setting of OAuthConnection) | RefreshToken | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RefreshTokenFileContent (Setting of OAuthConnection) | RefreshTokenFileContent | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RefreshTokenFilePath (Setting of OAuthConnection) | RefreshTokenFilePath | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RemoveAuthHeader (Setting of OAuthConnection) | RemoveAuthHeader | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RenewBeforeSec (Setting of OAuthConnection) | RenewBeforeSec | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RequestTokenUrl (Setting of OAuthConnection) | RequestTokenUrl | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RetainSameConnection (Setting of OAuthConnection) | RetainSameConnection | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RetryCountMax (Setting of OAuthConnection) | RetryCountMax | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RetryMessageList (Setting of OAuthConnection) | RetryMessageList | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RetryMode (Setting of OAuthConnection) | RetryMode |
| RetryMultiplyWaitTime (Setting of OAuthConnection) | RetryMultiplyWaitTime | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RetryStatusCodeList (Setting of OAuthConnection) | RetryStatusCodeList | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RetryWaitTimeMs (Setting of OAuthConnection) | RetryWaitTimeMs | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ReturnUrl (Setting of OAuthConnection) | ReturnUrl | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Scope (Setting of OAuthConnection) | Scope | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ScopeSeparator (Setting of OAuthConnection) | ScopeSeparator | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| ServiceProvider (Setting of OAuthConnection) | ServiceProvider |
| SignatureMethod (Setting of OAuthConnection) | SignatureMethod | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| SslVersion (Setting of OAuthConnection) | SslVersion |
| StreamReadWriteTimeoutMs (Setting of OAuthConnection) | StreamReadWriteTimeoutMs | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| SupportDualProxyMode (Setting of OAuthConnection) | SupportDualProxyMode | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Timeout (Setting of OAuthConnection) | Timeout | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| TimestampForTesting (Setting of OAuthConnection) | TimestampForTesting | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| TimestampOffset (Setting of OAuthConnection) | TimestampOffset | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| TokenRefreshMode (Setting of OAuthConnection) | TokenRefreshMode |
| TokenUIMode (Setting of OAuthConnection) | TokenUIMode |
| TokenUrl (Setting of OAuthConnection) | TokenUrl | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| UseCustomApp (Setting of OAuthConnection) | UseCustomApp | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| UseLoopbackUrlForDefault (Setting of OAuthConnection) | UseLoopbackUrlForDefault | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| UserName (Setting of OAuthConnection) | UserName | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| UseThirdPartyWebRequest (Setting of OAuthConnection) | UseThirdPartyWebRequest | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| UseWebProxy (Setting of OAuthConnection) | UseWebProxy | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Request Settings | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| DataConnectionType (Setting of CsvConfigurationParams) | Authentication type | Specifies the type of authentication to use to access data.
| DataPath (Setting of CsvConfigurationParams) | Data Source (URL or File Path) | Data source URL or File Path (e.g. http://abc.com/api/get --or-- c:\data\cust01.json --or-- c:\data\cust*.json ). If data source is file then wildcard pattern can be also used to read multiple files (e.g. c:\data\cust*.json will read all files that match wildcard) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Status Check Settings (Polling) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| EnableStatusCheck (Setting of CsvConfigurationParams) | EnableStatusCheck | Enable status check loop. When this option is enabled web requests are tried every N seconds to check desired value in response. Once desired value is found response is returned. Error is returned if failure indicator found or timeout occurs (i.e. Max iteration reached and still no success value found in the response). | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| StatusCheckForFailedValue (Setting of CsvConfigurationParams) | StatusCheckForFailedValue | Enable check to look for failure indicator. By default only SuccessValue is searched in response unless you set this option to true. Set StatusFailedValue to indicate failure regex / string pattern. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| StatusCheckIterationWaitSeconds (Setting of CsvConfigurationParams) | StatusCheckIterationWaitSeconds | Wait time between each iteration for status check | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| StatusCheckMaxWaitSeconds (Setting of CsvConfigurationParams) | StatusCheckMaxWaitSeconds | Maximum wait time in seconds until we need to keep checking for success value or failure value indicator. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| StatusFailedValue (Setting of CsvConfigurationParams) | StatusFailedValue | Regex pattern or string value you like to search for Failure indicator (e.g. Cancelled|Aborted|Failed ). Set StatusCheckForFailedValue=true to use this value. | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| StatusFieldFilterExpr (Setting of CsvConfigurationParams) | StatusFieldFilterExpr | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| StatusFieldFilterType (Setting of CsvConfigurationParams) | StatusFieldFilterType |
| StatusSuccessValue (Setting of CsvConfigurationParams) | StatusSuccessValue | Regex pattern or string value you like to search for Success indicator (e.g. Done|Success|Ok ) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
