INSERT INTO table_name ( column_name_1 [, column_name_2] ... )
VALUES (value1 [, value2] ... )[;]
[WITH (option_name=option_value] [, ...]) ] [;]
[SOURCE ('MSSQL' | 'ODBC' | 'OLEDB'
,'driver_specific_connection_string'
,'driver_specific_sql_query'
UPDATE table_name
SET column_name_1 = some_value
[,column_name_2 = some_value]
UPDATE table_name
DELETE FROM table_name
WHERE condition[WITH (option_name=option_value] [, ...]) ] [;]
SELECT Id, LastName, FirstName
FROM Contact
Where LastName!='Smith'
ORDER BY LastName, FirstName
LIMIT 10
SELECT Id,FirstName, LastName, Account.Name FROM Contact
SELECT *
FROM Contact
LIMIT 10
#bulkmode SELECT Id, LastName, FirstName
FROM Contact
LIMIT 10
SELECT Account.Id,Account.Name
, (SELECT Contact.FirstName, Contact.LastName, Contact.Email FROM Account.Contacts)
FROM Account
SELECT Name,
(SELECT FirstName, LastName FROM Contacts ORDER BY CreatedDate LIMIT 5)
FROM Account
Where Name='ZappySys'
SELECT c.Id, c.LastName, a.Name
FROM Contact c,c.Account a
LIMIT 10
SELECT LeadSource, COUNT(Name) Cnt
FROM Lead
GROUP BY LeadSource
HAVING COUNT(Name) > 100
SELECT COUNT(Id) Total FROM Account Where Name LIKE 'A%'
SELECT Id, LastName, FirstName, Email, Account.Name
FROM Contact
Where LastModifiedDate < {{System::ContainerStartTime,TO_UTC_DATETIME}} AND LastModifiedDate > 1999-12-31T00:00:00Z AND CreatedDate < YESTERDAY
LIMIT 10
SELECT Id, Name
FROM Account
WHERE Id IN
SELECT AccountId
FROM Contact
WHERE LastName LIKE 'a%'
AND Id IN
SELECT AccountId
FROM Opportunity
WHERE isClosed = false
SELECT Id FROM Account WHERE Name = 'Sam\'s Farm'
UPDATE account SET name='New Company Name', BillingState='GA' WHERE id IN ('0014N00001hTNEEQA4')
WITH(
Output=1 /*Other values can be Output='*' , Output=1 , Output=0 , Output='Col1,Col2...ColN'. When Output option is supplied then error is not thrown but you can capture status and message in __RowStatus and __ErrorMessage output columns*/
--,IgnoreFieldsIfInputNull=1 --Set this option to True if you wish to ignore fields if input value is NULL. By default target field is set to NULL if input value is NULL.
--,FieldsToSetNullIfInputNull='SomeColum1,SomeColumn5,SomeColumn7' --Comma separated CRM entity field names which you like to set as NULL when input value is NULL. This option is ignored if IgnoreFieldsIfInputNull is not set to True.
--,AssignmentRuleId='xxxxx' --rule id to invoke on value assignment
--,UseDefaultAssignmentRule=1 --sets whether you like to use default rule
--,AllOrNone=1 --If true, any failed records in a call cause all changes for the call to be rolled back. Record changes aren't committed unless all records are processed successfully. The default is false. Some records can be processed successfully while others are marked as failed in the call results.
--,OwnerChangeOptions='option1,option2...optionN' -- use one or more options from below. Use '-n' suffix to disable option execution e.g. TransferOpenActivities-n
-->>> Available owner change options: EnforceNewOwnerHasReadAccess,TransferOpenActivities,TransferNotesAndAttachments,TransferOthersOpenOpportunities,TransferOwnedOpenOpportunities,TransferOwnedClosedOpportunities,TransferOwnedOpenCases,TransferAllOwnedCases,TransferContracts,TransferOrders,TransferContacts,TransferArticleOwnedPublishedVersion,TransferArticleOwnedArchivedVersions,TransferArticleAllVersions,KeepAccountTeam,KeepSalesTeam,KeepSalesTeamGrantCurrentOwnerReadWriteAccess,SendEmail
-->>> For more information visit https://zappysys.com/link/?id=10141
--,AllowFieldTruncation=1 --If true, truncate field values that are too long, which is the behavior in API versions 14.0 and earlier.
--,AllowSaveOnDuplicates=1 --Set to true to save the duplicate record. Set to false to prevent the duplicate record from being saved.
--,EnableParallelThreads=1 --Enables sending Data in multiple threads to speedup. This option is ignored when bulk mode enabled (i.e. EnableBulkMode=1)
--,MaxParallelThreads=6 --Maximum threads to spin off to speedup write operation. This option is ignored when bulk mode enabled (i.e. EnableBulkMode=1)
--,TempStorageMode='Disk' --or 'Memory'. Use this option to overcome OutOfMemory Error if you processing many rows. This option enables how Temp Storage is used for query processing. Available options 'Disk' or 'Memory' (Default is Memory)
INSERT INTO Account(Name, BillingCity,PK__c)
VALUES ('mycompany name', 'New York','K100')
WITH(
DELETE FROM account WHERE id IN ('0014N00001hTNEEQA4')
WITH(
UPSERT INTO Account(Name, BillingCity,SupplierId__c)
WITH (KEY='SupplierId__c',Output=1)
UPDATE account
SET [Owner.Some_External_Id__c(User)]='SOME-EXT-ID-001'
--OR use salesforce internal Id--
--SET Owner='001xxxxxxxxQB2'
WITH(
UPDATE account
WITH( OwnerChangeOptions = 'TransferAllOwnedCases,TransferContracts,TransferOrders'
, AllowSaveOnDuplicates=0, AllowFieldTruncation=0, AllOrNone=0
--WITH(OwnerChangeOptions = 'TransferAllOwnedCases-n,TransferContracts-n,TransferOrders') -- In this line we added '-n' suffix which means do not execute TransferAllOwnedCases and TransferContracts but execute only TransferOrders
--Some possible values for OwnerChangeOptions are below
-- EnforceNewOwnerHasReadAccess
-- TransferOpenActivities
-- TransferNotesAndAttachments
-- TransferOthersOpenOpportunities
-- TransferOwnedOpenOpportunities
-- TransferOwnedClosedOpportunities
-- TransferOwnedOpenCases
-- TransferAllOwnedCases
-- TransferContracts
-- TransferOrders
-- TransferContacts
-- TransferArticleOwnedPublishedVersion
-- TransferArticleOwnedArchivedVersions
-- TransferArticleAllVersions
-- KeepAccountTeam
-- KeepSalesTeam
-- KeepSalesTeamGrantCurrentOwnerReadWriteAccess
-- SendEmai
--To see all possible values for OwnerChangeOptions visit https://zappysys.com/links/?id=10141
WITH(
UPDATE account SET [Owner.SomeExternalId__c(User)]='USR0001' --where Owner is relation name and (User) is object name which contains SomeExternalId__c field (Note: __c suffix is used for custom field)
WITH(
INSERT INTO Account(Name, BillingCity, [Owner.SomeExternalId__c(User)] ) VALUES ('mycompany name', 'New York','K100')
WITH(
UPSERT INTO Account(Name, BillingCity,[Owner.SomeExternalId__c(User)])
INSERT INTO Account
SOURCE('MSSQL' --external driver type (MSSQL, ODBC, OLEDB)
--driver specific connection string (i.e. MSSQL, ODBC, OLEDB)
--SQL Mixed Mode:
, 'Data Source=localhost;Initial Catalog=tempdb;User ID=user1;Password=mypass123;Integrated Security=false'
--OR- SQL Windows Auth: (For this to work - ZappySys Data Gateway Service Account must be added as SQL Server Login) -- See https://zappysys.com/links/?id=10151
--, 'Data Source=localhost;Initial Catalog=tempdb;Integrated Security=true'
,'select ''Account001'' as Name,''City001'' as BillingCity,1 as NumberofLocations__c UNION
select ''Account002'' as Name,''City002'' as BillingCity,2 as NumberofLocations__c UNION
select ''Account003'' as Name,''City003'' as BillingCity,3 as NumberofLocations__c '
--query for external system (i.e. MSSQL). Output column names in query must match columns found in target table (i.e. Account).
--To see all possible columns in target, select table from dropdown on the preview tab
WITH(
--,EnableBulkMode=1 --use this to invoke Bulk API (usually slower for less number of rows, works better for large dataset 5K+)
--OR--
,EnableParallelThreads=1 --//Send records in multiple threads for faster data processing (2000 rows sent in each batch). If you use EnableBulkMode=1 then this option is ignored and 500000 rows processed (in V2) in a each batch (in V1 its 10000) using Job Style API rather than Real Time API (faster for less than few hundred rows).
,MaxParallelThreads=6 --//Maximum threads to use for parallel processing
INSERT INTO Account
SOURCE('ODBC' --external driver type (MSSQL, ODBC, OLEDB)
,'Driver={ZappySys CSV Driver};DataPath=c:\somefile.csv' --driver specific connection string (i.e. MSSQL, ODBC, OLEDB)
,'SELECT Acct_Name as Name,Billing_City as BillingCity,Locations as NumberofLocations__c
FROM $
WITH(
--You can use SRC=xxxxxx or static data using DATA=xxxxxx attribute below (either or). For example purpose we use static data but in real world you will read from file so comment DATA=xxx
--SRC=''c:\file_1.csv''
--SRC=''c:\some*.csv''
--SRC=''https://abc.com/api/somedata-in-csv''
DATA = ''Acct_Name,Billing_City,Locations
Account001,City001,1
Account002,City002,2
Account003,City003,3
--query for external system (i.e. MSSQL). Output column names in query must match columns found in target table (i.e. Account) this is the reason we used alias in names.
WITH(
--OR--
INSERT INTO Account
--SQL Mixed Mode:
,'select top 1000000 C_NAME as Name,C_CITY as BillingCity, C_LOC as NumberofLocations__c From very_large_staging_table'
WITH(
,EnableBulkMode=1 --use Job Style Bulk API (uses 10000 rows per batch rather than 200)
--,MaxRowsPerJob=500000 --useful to control memory footprint in driver
--,ConcurrencyMode='Default' /* or 'Parallel' or 'Serial' - Must set BulkApiVersion=2 to use this, Bulk API V1 doesnt support this yet. If you get locking errors then change to Serial*/
--,BulkApiVersion=2 --default is V1
INSERT INTO Account
--SQL Mixed Mode:
,'select top 1000000 Account_Name as Name,AccountOwnerId as [Owner.ExternalId] From very_large_staging_table'
WITH(
DELETE FROM Account
--SQL Mixed Mode:
,'select top 1000000 Account_ID as Id From very_large_staging_table'
WITH(
UPDATE Account
--SQL Mixed Mode:
,'select top 1000000 Account_ID as Id, Account_Name as Name,City as BillingCity From very_large_staging_table'
WITH(
UPDATE Account
--SQL Mixed Mode:
,'select top 1000000 Account_ID as Id, Account_Name as Name,AccountOwnerId as [Owner.ExternalId] From very_large_staging_table'
WITH(
