This page lists all possible attributes you can use in ConnectionString or WITH clause of SQL Query. If you are not sure how to write correct connection string then perform following steps.
  1. Search for odbcad32 in the start menu. Click to launch it.
  2. Configure desired properties in the grid and check Query Preview to make sure everything is correct.
  3. Click on [Copy Connection String] button to generate full connection string.
Connection String Examples
Syntax: (Direct Connection string without DSN)
Driver={ZappySys Salesforce Driver}[,Attribute1=Value;][,Attribute2=Value;]........[,Attribute3=Value;]
Syntax: (Using DSN)
DSN=YourDsnName;[,Attribute1=Value;][,Attribute2=Value;]........[,Attribute3=Value;]
Connection String Attributes
AttributeLabelDescription
ConnectionStringFile
(Setting of SalesforceConfigurationParams)
Pwd
PwdMaps to ODBC 'Password'. Default: Basic auth Password. For OAuth/modern auth without Password, map Uid into another field (e.g. ClientSecret) by setting that field's value to {$pwd$}.
Uid
UidMaps to ODBC 'User Name'. Default: Basic auth UserName. For OAuth/modern auth without UserName, map Uid into another field (e.g. ClientId) by setting that field's value to {$uid$}.
Cache Settings
CacheEntryTtl
Cache entry lifetime, secThis property indicates how many seconds data is kept in cache (in case caching is enabled)
CacheFileLocation
Cache file locationThis property allows you to set cache file location (you have to set Cache persistence mode to Storage)
CacheStorage
Cache storageSpecifies cache storage - in-memory only or local data file
Available Options
Memory Memory
File File
CachingMode
Cache modeEnables or disables cache usage for metadata / data
Available Options
Disabled Caching disabled
Metadata Cache metadata
All Cache all
Error Handling Settings
ConvErrorHandlingMode
Error handling for data conversionDetermines whether data conversion errors are ignored or interrupt execution.
Available Options
ThrowError Stop execution on data conversion error
Ignore Ignore data conversion errors
TruncationHandlingMode
Error handling for data truncationDetermines whether data truncation errors are ignored or interrupt execution. This setting is only used when custom META is supplied or ConvErrorHandlingMode is set to Ignore errors.
Available Options
Truncate Truncate data (default)
ThrowError Stop with error on data truncation
Ignore Ignore data truncation errors
Log Settings
LoggingLevel
Log levelSets level of messages logged
Available Options
None None
Error Error
Debug Debug
Info Info
LogPath
Log file locationSets location for the log file (empty value means no log written)
LogRollingMode
Log rolling modeSets log file rolling mode. Log file may be restricted by log file size or by number of latest log files (one log file per day).
Available Options
Size Size (MB)
Days Days
LogSize
Maximum log file size (Mb)Sets limit for log file size (0 means no limit, old log entries will be discarded if size limit is reached)
MaxLogFiles
Number of log files to keep (0 - keep all, actual for LogRollingMode=Days)Set a number to keep N latest log files. Actual for LogRollingMode=Days. Set 0 to keep all files.
Reference
(Setting of ColumnDescriptor)
Reference
GroupName
(Setting of ColumnsMetadata)
Group name
OverrideMode
OverrideMode
Metadata Settings
MetaScanMode
Metadata Scan Mode / MultiplierMetadata guess mode / multiplier to detect length by scanning rows defined in
Available Options
Auto Auto
Strict Strict - Exact length
Guess2x Guess2x - 2 times bigger
Guess3x Guess3x - 3 times bigger
Guess4x Guess4x - 4 times bigger
TreatAsUnicodeString Set all columns as string
Guess10x Guess10x - 10 times bigger
TreatStringAsMaxLength Set string columns with MAX Length - i.e. DT_WSTR(4000)
TreatStringAsBlob Set string columns as BLOB - i.e. DT_NTEXT
MetaTreatStringAsAscii
Treat string as ASCIIWhen this option is true, it detects all string values as DT_STR (Ascii) rather than DT_WSTR (Unicode)
RowsToScanForMetadata
Number of rows scanned to collect metadataIf metadata isn't defined for query the driver will try to scan some rows to guess fields parameters
TreatBlankBoolAsNull
Treat blank BOOLEAN value as NULL
TreatBlankDateAsNull
Treat blank DATE/TIME value as NULL
TreatBlankNumberAsNull
Treat blank NUMERIC value as NULL
Other Settings
RegexReplaceListForSql
List of regular expressions for SQL modificationRegular expressions and replacement patterns are applied to SQL request executed by the driver, for instance: (?<column>\w+)=True||(?<column>\w+)=False|~|${column}=1||${column}=0 will replace all instances of SomeColumn=True with SomeColumn=1 and all instances of SomeColumn=False with SomeColumn=0 in all SQL requests. You can use regex group name as ${some-group-name} (only if defined as (?<some-group-name>..) anywhere in the regex) or use regex group number in the replacement string (e.g. $1, $2..). Regex pattern match is case-insensitive.
Output Settings
DefaultRowLimit
Default data row limit (i.e. LIMIT / TOP clause)Use this option if you like to limit number of rows fetched by any query. If you use LIMIT clause in the query then this option is ignored.
IncludeDeleted
Include Deleted Rows in the Output for SELECTUse this flag to include deleted records in SELECT query that have been deleted because of a merge or delete. Basically this flag invokes queryAll() API rather query(). With this flag you will see other records along with deleted records where isDeleted is true.
OutputOption
Default Output Option for Insert/Update/DeleteBy default Output=1 for WITH clause in INSERT/UPDATE/DELETE when not specified. Use this option to control default option. This is useful when ODBC Bulk INSERT invoked by some ETL Tools where you cannot supply WITH clause and like to mimic Output=0 so some errors are thrown if some insert records failed. By default when Output=1 then errors not thrown rather displayed in the output as rows.
Query Engine Temp Storage
TempStorageMode
Intermediate results storageUse [Disk] if number of resulting rows or row data size is large
Available Options
Memory Memory
Disk Disk
CertificatePassword
(Setting of ClientCertificateInfo)
CertificatePassword
CertificatePath
CertificatePath
DisplayPath
DisplayPath
EnableCertificate
EnableCertificate
IgnoreValidationErrors
IsServiceAccount
IsServiceAccount
StorageType
StorageType
Available Options
NotSet <Not set>
LocalMachine Stored in LocalMachine Storage Area
CurrentUser Stored in User Storage Area
PfxFile Disk File: *.pfx / *.p12 format (PKCS#12)
PemFile Disk File: *.pem format (PKCS#8, PKCS#1)
StoreName
StoreName
Available Options
NotSet <Not set>
AddressBook AddressBook
AuthRoot AuthRoot
CertificateAuthority CertificateAuthority
Disallowed Disallowed
My My
Root Root
TrustedPeople TrustedPeople
TrustedPublisher TrustedPublisher
Thumbprint
Thumbprint
LogLevel
(Setting of ILogger)
LogLevel
Available Options
Normal Normal
Summary Summary
Detail Detail
Debugging Debugging
Disabled Disabled
PrefixTimestamp
PrefixTimestamp
DoNotUseDefaultProxy
(Setting of ProxyInfo)
EnableProxy
EnableProxy
ProxyAuthMode
ProxyAuthMode
Available Options
Basic Basic
Ntlm Ntlm
Digest Digest
ProxyDomain
ProxyDomain
ProxyHost
ProxyHost
ProxyPassword
ProxyPassword
ProxyPort
ProxyPort
ProxyType
ProxyType
Available Options
None None
Socks4 Socks4
Socks4a Socks4a
Socks5 Socks5
HttpConnect HttpConnect
ProxyUrl
ProxyUrl
ProxyUseCreds
ProxyUseCreds
ProxyUser
ProxyUser
MaxRetryCount
(Setting of RetryInfo)
MaxRetryCount
MessageListToHandle
MessageListToHandle
MultiplyWaitTimeForEachAttempt
RetryMode
RetryMode
Available Options
None Do not retry
RetryAny Retry for any web, io, timeout errors
RetryWhenStatusCodeMatch Retry for throttling or matching HTTP status code(s)  (e.g. 429|501)
RetryWhenMessageMatch Retry if error message contains specified string(s) (e.g. nessage1|message2)
StatusCodeListToHandle
WaitTimeMs
WaitTimeMs
AccessToken
(Setting of SalesforceConnection)
AccessToken
AllOrNone
AllOrNone
AllowFieldTruncation
AllowSaveOnDuplicates
ApiVersion
ApiVersion
AuthScheme
AuthScheme
AuthType
AuthType
Available Options
Default UserId / Password + SecurityToken (*** DEPRECATED ***)
OAuth OAuth 2.0 (Interactive: Useful when MFA/2FA enabled)
OAuthClientCreds OAuth 2.0 Client Credentials (Non-Interactive: Mimics RunAs)
AuthUrl
AuthUrl
ClientId
ClientId
ClientSecret
ClientSecret
ConnectionString
ConnectionString
ConnectionStringFull
ConnectionStringNonDefaultsOnly
ConnectionStringNonDefaultsOnlyFull
DisableCustomUrl
DisableCustomUrl
DisableSockProxySupport
DisableTest
DisableTest
DisableThirdPartWebRequest
Domain
Domain
EnablePkceCodeVerifier
ExtraAttributesForAuthRequest
ExtraAttributesForTokenRequestPersisted
ExtraHeaders
ExtraHeaders
HasEnableProxyOption
InstanceUrl
InstanceUrl
MetaBody
MetaBody
MetaContentType
MetaContentType
Available Options
None None
Json Json
Xml Xml
Regex Regex
MetaFields
MetaFields
MetaFilters
MetaFilters
MetaHeaders
MetaHeaders
MetaMethod
MetaMethod
MetaTemplate
MetaTemplate
MetaUrl
MetaUrl
OwnerChangeOptions
OwnerChangeOptions
Password
Password
PreferProxyUrl
PreferProxyUrl
RedirectUrl
RedirectUrl
RefreshToken
RefreshToken
RefreshTokenFilePath
RetainSameConnection
RetryCountMax
RetryCountMax
RetryMessageList
RetryMessageList
RetryMode
RetryMode
Available Options
None Do not retry
RetryMultiplyWaitTime
RetryStatusCodeList
RetryStatusCodeList
RetryWaitTimeMs
RetryWaitTimeMs
Scopes
Scopes
SecurityToken
SecurityToken
ServiceType
ServiceType
Available Options
Production Production
Sandbox Sandbox
Other Other
Developer Developer
ServiceUrl
ServiceUrl
SslVersion
SslVersion
Available Options
Default System Default
Ssl3 SSL v3.0
Ssl3Plus SSL v3.0 or higher
Tls TLS v1.0
TlsPlus TLS v1.0 or higher
Tls11 TLS v1.1
Tls11Plus TLS v1.1 or higher
Tls12 TLS v1.2
Tls12Plus TLS v1.2 or higher
Tls13 TLS v1.3
Any Any Version
StreamReadWriteTimeoutMs
SupportDualProxyMode
Timeout
Timeout
TimeoutInMiliseconds
TokenUrl
TokenUrl
Url
Url
UseIntegratedAuth
UseIntegratedAuth
UserName
UserName
UseThirdPartyWebRequest
UseWebProxy
UseWebProxy
