For detailed steps check this article
Example
using (OdbcConnection conn =
            new OdbcConnection("DRIVER ={ZappySys JSON Driver};DataPath='http://services.odata.org/V3/Northwind/Northwind.svc/Invoices?$format=json'"))
    conn.Open();
    cmd = new OdbcCommand(
@"SELECT
Country as Invoice_Country, SUM(UnitPrice * Quantity) Total
FROM value
GROUP BY Country
ORDERBY Total DESC", conn);
    var rdr = cmd.ExecuteReader();
    while (rdr.Read())
        Console.WriteLine("---- Fetching Row -------");
        for (i = 0; i < rdr.FieldCount; i++)
            Console.Write("Field {0}={1} ", i, rdr[i]);
        Console.WriteLine("");
Articles
Click here to see all articles for [C# (CSharp)] category
How to export REST API  to CSV using c# or Python
Introduction to export REST API to CSV Export REST API to CSV is in some cases necessary to process the data because many tools can handle CSV files. In this new article, we will show different ways to export the data. The first example will do it using C#. The second example with use Python. Let’s take a […]
Calling REST API in C# (Read JSON Data)
Introduction – REST API using C# In this post, We will use ZappySys ODBC Powerpack for calling REST API in C# (i.e. CSharp). We will create an ODBC connection to REST API and consume it different ways (e..g Bind API data to Data Grid, Combo Box or Write to File). ZappySys ODBC Driver allows to connect […]
