• .net framework: 4.0 or higher required (e.g. 4.0, 4.5, 4.6...)
  • Desktop OS: Windows 11, Windows 10, Windows 8, Windows 7
  • Server OS: Windows Server 2025, Windows Server 2022, Windows Server 2019, Windows Server 2016, Windows Server 2012 (R2), Windows Server 2008, Windows Server 2003
  • For JDBC Bridge Driver : You will need a minimum of Java 21; If the JDBC driver targets a higher Java version (e.g., 25+), then make sure to install a higher Java Version (Check JDBC Driver Java version requirement).
    Recommended Java: Click here to Download (Java 21)
    See official Java download page: here
    Other Java Distributions: Above link is for OpenJDK by Amazon corretto but if you prefer Oracle Java or some other Java distribution then its fine too, just confirm version requirements above.
