This page lists all possible attributes you can use in ConnectionString or WITH clause of SQL Query. If you are not sure how to write correct connection string then perform following steps.
  1. Search for odbcad32 in the start menu. Click to launch it.
  2. Configure desired properties in the grid and check Query Preview to make sure everything is correct.
  3. Click on [Copy Connection String] button to generate full connection string.
Connection String Examples
Syntax: (Direct Connection string without DSN)
Driver={ZappySys SFTP CSV Driver}[,Attribute1=Value;][,Attribute2=Value;]........[,Attribute3=Value;]
Syntax: (Using DSN)
DSN=YourDsnName;[,Attribute1=Value;][,Attribute2=Value;]........[,Attribute3=Value;]
Connection String Attributes
AttributeLabelDescription
AccessMode
(Setting of CsvConfigurationParams)
AccessModeDefines how to read data from file path/URL or direct string
Available Options
DirectPath DirectPath
DirectValue DirectValue
ConnectionStringFile
Data
DirectValueDirect String you like to use as a datasource. This attribute always takes precedence if both Data and Src defined (i.e. File/Url). You can also use AccessMode=1 along with Data='...' in WITH clause to use Direct String rather than URL/File.
EnableCustomReplace
EnableCustomReplaceEnables custom search / replace in the document text after its read from the file/url or direct string. This replace operation happens before its parsed. This option can be useful for custom escape sequence in source document which is causing issue in the parser. You can replace such unwanted characters fore parser starts parsing the text.
IgnoreContentLengthHeaderForGzipResponse
Pwd
PwdMaps to ODBC 'Password'. Default: Basic auth Password. For OAuth/modern auth without Password, map Uid into another field (e.g. ClientSecret) by setting that field's value to {$pwd$}.
ReplaceWith
ReplaceWithString you like to replace with (Only valid when EnableCustomReplace option is turned on). If you added --regex or --regex-ic at the end of your SearchFor string then ReplaceWith can use numbered group placeholders (e.g. $1, $2...) or use group name as placeholder (e.g. ${username}, ${domain}) any where in the replacement string.
ReplaceWith = ****$2
-OR-
ReplaceWith = ****${domain}
SearchFor
SearchForString you like to search for (Only valid when EnableCustomReplace option is turned on). If you want to enable Regular Expression pattern search then add --regex or --regex-ic (for case-insensitive search)  at the end of your search string (e.g. ORDER-\d+--regex OR ORDER-\d+--regex-ic (case-insensitive search) )
Uid
UidMaps to ODBC 'User Name'. Default: Basic auth UserName. For OAuth/modern auth without UserName, map Uid into another field (e.g. ClientId) by setting that field's value to {$uid$}.
Cache Settings
CacheEntryTtl
Cache entry lifetime, secThis property indicates how many seconds data is kept in cache (in case caching is enabled)
CacheFileLocation
Cache file locationThis property allows you to set cache file location (you have to set Cache persistence mode to Storage)
CacheStorage
Cache storageSpecifies cache storage - in-memory only or local data file
Available Options
Memory Memory
File File
CachingMode
Cache modeEnables or disables cache usage for metadata / data
Available Options
Disabled Caching disabled
Metadata Cache metadata
All Cache all
CSV Settings
AllowComment
AllowCommentAllow comment lines which can be skipped by parser. When comment line found row is skipped. See CommentCharacter to configure first character for commented line.
ColumnDelimiter
ColumnDelimiterColumn delimiter for data you like to parse. To use custom delimiter enter 4-digit hex string starting with \x (e.g. you can enter \x0009 for Tab character). For multiple characters repeat group. e.g. \x00090009 if you need two tabs.
CommentCharacter
CommentCharacterAllow lines with comment. When comment line found row is skipped. See LineCommentCharacter property to configure first character for commented line.
HasColumnHeaderRow
HasColumnHeaderRowColumn delimiter for data you like to parse.
IgnoreBlankLines
IgnoreBlankLines
IgnoreQuotes
IgnoreQuotesIgnore quote character and consider it part of actual value
QuoteCharacter
QuoteCharacterQuote character for quoted values.
SkipEmptyRecords
SkipEmptyRecordsWhen this option is enabled, any row with empty values in all fields is skipped (e.g. , , , , ).
SkipHeaderCommentRows
SkipHeaderCommentRowsTotal rows you like to skip before header row. If its header less file then skip initial N rows (before any data row).
SkipRows
SkipRowsTotal data rows you like to skip (after header row)
ThrowErrorOnColumnCountMismatch
ThrowErrorOnColumnCountMismatchThrow error if record has different number of columns than actual columns detected based on first row
ThrowErrorOnNoRecordFound
ThrowErrorOnNoRecordFoundThrow error if no record found or file is blank
TreatBlankAsNull
TreatBlankAsNull
TrimFields
TrimFieldsTrim value for each field if whitespace found before or after
TrimHeaders
TrimHeadersTrim column names if whitespace found before or after name
Encoding / Culture Settings
CharacterSet
CharacterSetCharacter set for text (e.g. utf-8 )
Culture
CultureCulture code (e.g. pt-BT). This helps to parse culture specific number formats (e.g. In some culture you may have comma rather than decimal points 0.1 can be 0,1)
Encoding
EncodingEncoding of source file
Available Options
Default Default
ASCII ASCII
UTF8 UTF-8
UTF16 UTF-16 LE (i.e. Unicode Little Endian)
UTF32 UTF-32
UTF8WithoutBOM UTF-8 Without BOM
UTF32WithoutBOM UTF-32 Without BOM
UTF7 UTF-7
UTF7WithoutBOM UTF-7 Without BOM
UTF16WithoutBOM UTF-16 Without BOM
BigEndian UTF-16 BE (i.e. Unicode Big Endian)
BigEndianWithoutBOM UTF-16 BE Without BOM
Error Handling Settings
ConvErrorHandlingMode
Error handling for data conversionDetermines whether data conversion errors are ignored or interrupt execution.
Available Options
ThrowError Stop execution on data conversion error
Ignore Ignore data conversion errors
TruncationHandlingMode
Error handling for data truncationDetermines whether data truncation errors are ignored or interrupt execution. This setting is only used when custom META is supplied or ConvErrorHandlingMode is set to Ignore errors.
Available Options
Truncate Truncate data (default)
ThrowError Stop with error on data truncation
Ignore Ignore data truncation errors
Log Settings
LoggingLevel
Log levelSets level of messages logged
Available Options
None None
Error Error
Debug Debug
Info Info
LogPath
Log file locationSets location for the log file (empty value means no log written)
LogRollingMode
Log rolling modeSets log file rolling mode. Log file may be restricted by log file size or by number of latest log files (one log file per day).
Available Options
Size Size (MB)
Days Days
LogSize
Maximum log file size (Mb)Sets limit for log file size (0 means no limit, old log entries will be discarded if size limit is reached)
MaxLogFiles
Number of log files to keep (0 - keep all, actual for LogRollingMode=Days)Set a number to keep N latest log files. Actual for LogRollingMode=Days. Set 0 to keep all files.
Reference
(Setting of ColumnDescriptor)
Reference
GroupName
(Setting of ColumnsMetadata)
Group name
OverrideMode
OverrideMode
Metadata Settings
MetaScanMode
Metadata Scan Mode / MultiplierMetadata guess mode / multiplier to detect length by scanning rows defined in
Available Options
Auto Auto
Strict Strict - Exact length
Guess2x Guess2x - 2 times bigger
Guess3x Guess3x - 3 times bigger
Guess4x Guess4x - 4 times bigger
TreatAsUnicodeString Set all columns as string
Guess10x Guess10x - 10 times bigger
TreatStringAsMaxLength Set string columns with MAX Length - i.e. DT_WSTR(4000)
TreatStringAsBlob Set string columns as BLOB - i.e. DT_NTEXT
MetaTreatStringAsAscii
Treat string as ASCIIWhen this option is true, it detects all string values as DT_STR (Ascii) rather than DT_WSTR (Unicode)
RowsToScanForMetadata
Number of rows scanned to collect metadataIf metadata isn't defined for query the driver will try to scan some rows to guess fields parameters
TreatBlankBoolAsNull
Treat blank BOOLEAN value as NULL
TreatBlankDateAsNull
Treat blank DATE/TIME value as NULL
TreatBlankNumberAsNull
Treat blank NUMERIC value as NULL
Other Settings
DateParseHandling
Date data typeSpecifies how dates are parsed.
Available Options
None Keep date as string
DateTime Convert to DateTime (Timezone lost)
DateTimeOffset Convert to DateTimeOffset (Preserve Time zone)
EnableBigNumberHandling
Enable Big Number HandlingWhen this option is checked, sytem allows to parse large number (Higher than Int64) in JSON document (i.e. { id: 76000009353950433247780 } ). If you do not turn on this option then it may throw error if large number is encountered. This option is SLOW becuase it has to perform additional checks in order to avoid Large number overflow error so do not turn on unless you getting Large number error.
FloatParseHandling
FloatParseHandlingSpecifies how decimal values are parsed when reading JSON. Change this setting to Decimal if you like to have large precision / scale.
Available Options
Double Default (Double [~15-17 digits])
Decimal Decimal (High Precision / Scale [~28-29 digits] )
Recursive
Scan files recursivelyScan files recursively when you read from local  files (i.e. include files from sub folders).
RegexReplaceListForSql
List of regular expressions for SQL modificationRegular expressions and replacement patterns are applied to SQL request executed by the driver, for instance: (?<column>\w+)=True||(?<column>\w+)=False|~|${column}=1||${column}=0 will replace all instances of SomeColumn=True with SomeColumn=1 and all instances of SomeColumn=False with SomeColumn=0 in all SQL requests. You can use regex group name as ${some-group-name} (only if defined as (?<some-group-name>..) anywhere in the regex) or use regex group number in the replacement string (e.g. $1, $2..). Regex pattern match is case-insensitive.
Output Settings
DateFormatString
Date formatSpecifies date format
DefaultRowLimit
Default data row limit (i.e. LIMIT / TOP clause)Use this option if you like to limit number of rows fetched by any query. If you use LIMIT clause in the query then this option is ignored.
EnableArrayFlattening
Enable Array FlatteningEnables deep array flattening for selected filtered hierarchy. When you turn on this property it will flatten each property of each array item and expose as column (e.g. If you have Filter set as $.customers[*] and for each customer you have an array of Addresses then you may see output columns like Addresses.1.City, Addresses.1.State, Addresses.2.City, Addresses.2.State .... Addresses.N.City, Addresses.N.State). You can control how many array items you want to flatten by setting MaxArrayItemsToFlatten property.
EnablePivot
Enable PivotWhen this property is true then Column is converted to Row. Pivoted names will appear under  Pivot_Name column and values will appear under Pivot_Value field.
EnableRawOutputModeSingleRow
Enable Raw Document - Single Row (Disable parser, allow any format)Enable Raw Document Output Mode for any format (i.e. XML, Html, Text, Json). Unlike other option EnableRawOutputMode, this option doesn't invoke parser to extract documents by finding row terminator. It will source string as row value in single row/ single column.
FileCompressionType
FileCompressionTypeCompression format for source file (e.g. gzip, zip)
Available Options
None None
GZip GZip
Zip Zip
TarGZip TarGZip
Max Array Items To FlattenMaximum number of array items to flatten. inner array flattening. Adjust this property to control how many columns being generated. This option is ignored if you set EnableArrayFlattening=false
RawOutputDataRowTemplate
RawOutputExtractMode
Available Options
None None
Json Json
Xml Xml
Regex Regex
RawOutputFilterExpr
RawOutputFilterExprUse this property to define one or multiple expressions (i.e. JsonPath,XPath,Regex) to extract information from source. This property is only valid when EnableRawOutputModeSingleRow=true and RawOutputDataRowTemplate is set.
SaveContentAsBinary
SaveContentAsBinary
Query Engine Temp Storage
TempStorageMode
Intermediate results storageUse [Disk] if number of resulting rows or row data size is large
Available Options
Memory Memory
Disk Disk
Request Settings
DataPath
Data Source (URL or File Path)Data source URL or File Path (e.g. http://abc.com/api/get --or-- c:\data\cust01.json  --or-- c:\data\cust*.json ). If data source is file then wildcard pattern can be also used to read multiple files (e.g. c:\data\cust*.json will read all files that match wildcard)
