This page lists all possible attributes you can use in ConnectionString or WITH clause of SQL Query. If you are not sure how to write correct connection string then perform following steps.
  1. Search for odbcad32 in the start menu. Click to launch it.
  2. Configure desired properties in the grid and check Query Preview to make sure everything is correct.
  3. Click on [Copy Connection String] button to generate full connection string.
Connection String Examples
Syntax: (Direct Connection string without DSN)
Driver={ZappySys Jdbc Driver}[,Attribute1=Value;][,Attribute2=Value;]........[,Attribute3=Value;]
Syntax: (Using DSN)
DSN=YourDsnName;[,Attribute1=Value;][,Attribute2=Value;]........[,Attribute3=Value;]
Connection String Attributes
AttributeLabelDescription
Cache Settings
CacheEntryTtl
(Setting of JdbcConfigurationParams)
Cache entry lifetime, secThis property indicates how many seconds data is kept in cache (in case caching is enabled)
CacheFileLocation
Cache file locationThis property allows you to set cache file location (you have to set Cache persistence mode to Storage)
CacheStorage
Cache storageSpecifies cache storage - in-memory only or local data file
Available Options
Memory Memory
File File
CachingMode
Cache modeEnables or disables cache usage for metadata / data
Available Options
Disabled Caching disabled
Metadata Cache metadata
All Cache all
Error Handling Settings
ConvErrorHandlingMode
Error handlingDetermines whether some conversion errors are ignored or stop query processing.
Available Options
ThrowError Stop execution on error
Ignore Ignore errors
Log Settings
LoggingLevel
Log levelSets level of messages logged
Available Options
None None
Error Error
Debug Debug
Info Info
LogPath
Log file locationSets location for the log file (empty value means no log written)
GroupName
(Setting of ColumnsMetadata)
Group name
Metadata Settings
TreatBlankBoolAsNull
Treat blank BOOLEAN value as NULL
TreatBlankDateAsNull
Treat blank DATE/TIME value as NULL
TreatBlankNumberAsNull
Treat blank NUMERIC value as NULL
Output Settings
DefaultRowLimit
Default data row limit (i.e. LIMIT / TOP clause)Use this option if you like to limit number of rows fetched by any query. If you use LIMIT clause in the query then this option is ignored.
Request Settings
ClassName
Driver class
DriverPath
JDBC driver path
JdbcConnectionString
Connection string
UserName
User name
UserPassword
User password
