SSIS Salesforce Connection Manager
SSIS Salesforce Connection Manager can be used with Salesforce Source, Salesforce Destination, Salesforce API Task, JSON Source and XML Source to read/write Salesforce.com data or execute various actions via API calls.
In this tutorial we will learn how to create Salesforce Connection. You can create multiple connection too.
  1. To develop ETLs in Salesforce using SSIS you’ll need a Salesforce Developer account. If you don’t have one, don’t worry, you can create a limited version FREE developer account. Click here to Sign up for FREE developer account.
    In order to connect to Salesforce Storage from SSIS you will need User Name, Password and Security Token. Your keys will look something like this: (this is just example which may differ in your case).
         User Name : yourusername@yourcompanyname.com
    Security Token : 1Abcd2efg3uHL4bda9PTS2l7
    click here to learn how to obtain Salesforce Security Token.
  2. Now, You need to Download and Install SSIS ZappySys PowerPack.
  4. Right click in the Connection Manager panel and click on New Connection.
    SSIS Create New Connection
  5. Select ZS-SALESFORCE Connection Manager from the Connection Managers list and Click on Add Button.
    SSIS Salesforce Connection Manager - ADD
  6. Now in Connection Manager UI, Enter your SalesForce Credentials (User Name, Password and Security Token), and leave all other properties as it is.
    SSIS Salesforce Connection Manager UI
  7. In the Proxy Tab, you can set your proxy settings here.
    SSIS Salesforce Connection Manager - Proxy
  8. In the Error Retry Settings, you can use more settings.
    SSIS Salesforce Connection Manager - Error Setting
  9. Click on Test Connection to check configure correct or not.
  10. Click on OK button to save Salesforce COnnection Manager configure setting UI.
  11. Once you finished, you will see Salesforce connection in Connection Manager panel.
    SSIS Salesforce Connection Manager - Success
ServiceType
Production [0] Production
Sandbox [1] Sandbox
Other [2] Other
ServiceUrl
UseClientCertificate UseClientCertificate
ClientCertificateStorageType CertificateStorageType
NotSet [0] <Not set>
LocalMachine [1] Stored in LocalMachine Storage Area
CurrentUser [2] Stored in User Storage Area
PfxFile [3] Disk File - PFX (PKCS12) format
ClientCertificateStoreName CertificateStoreName
AddressBook [1] AddressBook
AuthRoot [2] AuthRoot
CertificateAuthority [3] CertificateAuthority
Disallowed [4] Disallowed
My [5] My
Root [6] Root
TrustedPeople [7] TrustedPeople
TrustedPublisher [8] TrustedPublisher
ClientCertificateThumbPrint CertificateThumbprint
ClientCertificatePath CertificatePath
ClientCertificatePassword
AllOrNone If true, any failed records in a call cause all changes for the call to be rolled back. Record changes aren't committed unless all records are processed successfully. The default is false. Some records can be processed successfully while others are marked as failed in the call results.
AllowFieldTruncation If true, truncate field values that are too long, which is the behavior in API versions 14.0 and earlier.
Default is false: no change in behavior. If a string or textarea value is too large, the operation fails and the fault code STRING_TOO_LONG is returned.
The following list shows the field types affected by truncation and this header:
anyType, if it represents one of the other datatypes in this list
email
encryptedstring
multipicklist
phone
picklist
string
textarea
AllowSaveOnDuplicates Set to true to save the duplicate record. Set to false to prevent the duplicate record from being saved.
Timeout Request timeout in seconds
UserName
Password
SecurityToken
AccessToken
RefreshToken
ClientSecret
ClientId
ApiVersion API Version to use for SOAP / Bulk API calls. If not supplied then default version is used which is 55.0
AuthType
Default [0] User Id / Password
OAuth [1] OAuth 2.0 (Useful when 2FA / MFA enabled)
AuthUrl
TokenUrl
RedirectUrl
Scopes
ProxyType Proxy server type
None [0] None
Socks4 [1] Socks4
Socks4a [2] Socks4a
Socks5 [3] Socks5
HttpConnect [4] HttpConnect
ProxyHost Proxy Server or IP (e.g. MyProxy01 --or-- 192.168.0.1 --or-- proxy1.mydomain.com)
ProxyPort Proxy server port number
ProxyAuthMode Proxy authentication mode
Basic [0] Basic
Ntlm [1] Ntlm
Digest [2] Digest
ProxyDomain Domain to submit to the proxy server for authentication.
ConnectionString
RetainSameConnection
RetryMode
None [0] Do not retry
RetryAny [1] Retry any web errors
RetryWhenStatusCodeMatch [2] Retry for matching response status code(s)
RetryWhenMessageMatch [3] Retry errors for matching error sub string(s)
RetryCountMax
RetryMessageList
RetryMultiplyWaitTime
RetryStatusCodeList
RetryWaitTimeMs
DoNotUseDefaultProxy Do not use system default proxy (This setting is ignored if UseProxy=true)
ProxyUseCreds Enable passing userid and password to proxy server
ProxyPassword Proxy password
ProxyUserName Proxy username
SSIS Salesforce Connection Manager - Setting UI
