SSIS JSON Parser Transform
SSIS JSON Parser Transform can parse JSON string into multiple columns and rows (Helpful to extract data from raw JSON string stored as database column or coming from other source).
ReplaceWith String you like to replace with (Only valid when EnableCustomReplace option is turned on). If you added --regex or --regex-ic at the end of your SearchFor string then ReplaceWith can use special placeholders (i.e. $1, $2...) based on regular expression groups. For example you SearchFor=(\w+)(@\w+.com) to search for emails then to mask emails you can something like this for ReplaceWith = ****$2 (where $2 is domain part and $1 is before @)
SampleData Sample JSON data used to parse output columns.
OutputAllUpstreamColumns Include all upstream parent columns into output except the one you selected to parse. By default only parsed columns from Input document is included in the output. If you wish to include all other upstream columns in the output too then check this option.
EmptyInputProcessingMode Defines how to handle empty input. By default NULL or Empty input is skipped from parsing.
IgnoreEmpty [0] Skip Empty / NULL documents
OutputAsNull [1] Process Empty / NULL documents
ThrowError [2] Throw Error on Empty / NULL documents
UseCustom [3] Use custom value for Empty / NULL documents
TreatEmptyInputAs Defines how to handle empty input. By default NULL or Empty input is skipped from parsing.
ExcludedProperties List comma separated property names from JSON document which you want to exclude from output. Specify parent property name to exclude all child nodes.
None [0] Keep date as string
None [0] None
RawOutputDataRowTemplate When you enable EnableRawOutputModeSingleRow you can use this property. Template must be in JSON format (e.g. { data: [$1] } ). [$1] means content extracted using first expression or no expression (i.e. raw data). If RawOutputFilterExpr contains multiple expressions (separated by || ) then you can use multiple placeholders (i.e. [$1], [$2]...[$N]). RawOutputFilterExpr can have JsonPath, XmlPath, RegEx (set RawOutputExtractMode).
Auto [0] Auto
Screenshots
SSIS JSON Parser Transform - Parse JSON Document, Convert JSON to CSV or save to RDBMS (e.g. SQL Server, MySQL)
SSIS JSON Parser Transform - Parse XMl Document, Convert JSON to CSV or save to RDBMS (e.g. SQL Server, MySQL)
Click here to see all articles for [SSIS JSON Parser Transform] category
How to Pivot CSV Data in SSIS
Introduction In our previous blog we saw How to write data into CSV file in SSIS (GZip / Split). Now in this blog, we will see How to Pivot CSV Data in SSIS using CSV Source. It also supports Pivot mode so you can convert single CSV string value into Rows. In this article we […]
How to read YouTube API data in SSIS (Videos, Channels, Playlists)
Introduction In last few articles we saw how to read data from various Google Services. In this article we will see how to read YouTube API data in SSIS. This blog mainly focus on SSIS approach but steps mentioned to call Google APIs can be useful for any developer regardless which programming language or toolset […]
SSIS Geocoding with Google Maps API
Introduction In this tutorial, we will cover the topics of how to perform geocoding on the addresses and reverse geocoding on the location coordinates using SSIS and Google Maps API. So what is geocoding, exactly? Geocoding is the process of translating an address (e.g. a street address) or a place to coordinates on the Earth’s surface. Simply […]
How to call Elasticsearch API using SSIS
Introduction Elasticsearch is a powerful engine that allows you to store, aggregate and, most importantly, search data in a very analytical way. In this tutorial, you will learn how to bulk load data from SQL Server to Elasticsearch with SSIS (part of SQL Server) and ZappySys PowerPack. The scope of this article will be to show how to import […]
